- Nov 3, 2003
- 51,622
...I think the blades suck the water from each side and push it out the middle out the outlet to the radiator.
Opposite of that.
Standard or reverse, the coolant always flows in the same direction through the radiator. Heated coolant flows out the top of the engine, into the radiator, and back into the engine from the bottom of the radiator after cooling.
The large port on the side of the pump is then always (on our engines anyway) the "inlet" side.
The two smaller internal ports on each side of the pump are the "outlets" through which coolant is pushed by the pump back into the block.
As far as I know, all engines run heated water into the top of a radiator and cooled water out of the bottom.
