Ride quality for stock Bronco
ky-resto
I'm in the process of getting my 72 Bronco back on the road. It's been sitting for most of the last 15-20 years. It was bone stock when I bought it and I've done some mods with the hope of better performance with a stock look. I did the F150 disc conversion and new ball joints, steering linkage (with tie rod ends using the JBG sleeves), and cheap motorcraft/monroe shocks while I had everything apart.
I took it for a test drive to test the brakes and the brakes worked fine. The steering and overall handling scared the crap out of me though. After reading posts from folks with similar issues, I replaced the track bar bushings with the energy suspension polys and the handling improved a little, but it still feels loose overall.
The tires are old 235/75/15 highway treads and the springs, C bushings and strut arm bushings are stock.
Do I need to replace all the suspension pieces for solid handling or can I get by with bushings? The manual steering box has some play, so I know i'll need to do something there.
What's the best handling I can expect with a stock ride height EB?
Deano
With all new bushings, shocks, alinement, new tires, and power steering. Should drive like a champ and ride good! My opinion. I put a 76 power steering box, track bar bushings, new tires and got it alined and it does great. I'm going to put bushings in the rest of it and some shocks over the summer.
ky-resto
ky-resto
Deano- thanks for the reply. What shocks and tires are you running?
ky-resto
ky-resto
did jamie oliver drive your bronco? I saw that show and love that bronco!
Deano
Yes Jamie did drive my bronco. I'm planning on putting some binstine shocks and BFGs or something like a 195 street truck tire as close to stock size as I can find.
bronco loco
It never ends
Long Island New York
I got bilsteins on mine along with wh horses stock height suspension using their 11 pack rear springs, made a big difference. Then decided to go with the 2.5 wh stilll rides great.
stout22
Athens, AL
If you have the stock bushings (30+ years old) replace them all. That's something I do on any new-to-me Bronco. The old stock rubber C-bushings tend to work themselves out and as a result the front end can shift unexpectedly:eek:
ky-resto
ky-resto
Thanks for the feedback guys. I found an oil change receipt from 1996 and the Bronco had 80 less miles than it does now. The c-bushings look like they're shot, so I'll follow Heuss33's how-to. Great article!
ky-resto
ky-resto
Regarding shocks, I found some NOS Motorcraft gas-charged shocks on e-bay. They were cheap and kind of retro looking, so I bought them. But I'm wondering if I need to upgrade. I can push down on the front fender and get the ole Bronco rocking like crazy. Should I get something a little more stiff? I've heard good things about the Bilsteins. Anyone using the JBG Superlift shocks? Thanks everyone.
