pk8950
I have multiple questions. Ill try to be as descriptive as possible.
#1 On the RJM efi harness the three wires that go back under dash. one goes to oil ,one goes to water temp, other(orange wire) is supposed to go to keyed run. RJM instructions show all other harness manuf. except aaw. What wire do I hooked the keyed run wire to?
#2 I got the 3g alt. form RJM it came with the wire to turn on alt. from efi harness. Between both the wiring diagrams I got myself confused. All this is wiring by the start solenoid and battery (Pass. front). The RJM harness has a red wire marked battery which I assume goes to the Pos. on the bat. Also it has a purple wire that is marked tfi start. Where do I hook that to?
The Aww harness has a number of wires I need help with. First white wire with coil/tach on it since I'm not using a tach I'm assuming I wont use. Next brown wire marked Alternator ign. Do I need this with the 3g alt. and the rjm wiring? Next is pink wire marked Ignition feed. next is a red wire marked 12v battery. Last a purple wire marked starter solenoid. Do I hook all this up or does my RJM harness already do some of this?
#3 With all this I don't have any idea how to wire the Alt., starter solenoid and battery. Any help would be appreciated.
