Roadster Door Insert Strength Question
2wheelbob
Tech question for those running the door inserts. I’m currently building a ‘75 Bronco Desert Racer. I want to use the roadster style door inserts. I noticed there are a few options, from two piece ones with steel insets to one piece ones. Which ones will be the strongest to use in a race application? I dont expect to be beating the truck up but it will be exposed to rocks, dirt, brush, and track debris. I’m looking for feedback from your real world experience. Thanks in advance!
4xfun
No experiencing with racing, but it seems like you would want to use doors to help reduce body flexing.. Maybe tube doors?
tasker
all knowing of nothing
NH
I ran the one piece inserts for years, HARD. not racing but daily use on roads/woods all but 4/5 months a year. Found them to be extremely durable
If you are going to damage one style, you will damage the other style as well. None are structural. Either style is just a cosmetic filler. The difference really comes down to how the inner voids are closed off. I did have a set that had no closeout on them. Handy for storing some small junk.
For racing, get which ever you find a better price on.
EPB72
Pleasant Hill, CA
Door or inserts there would be some flex if all twisted up rock crawling , doors only have one anchor point on rear pillar that is not a 100%solid,, A well built safety cage would mostly eliminate this flex ,, I had duff inserts from the early 80’s durable but would have little effect on resisting body flex,,, but if concerned with strength you could add more fiber glass to the back unseen side if needed,..
