Roadster option question.
broncorick
One option available on roadsters were doors with no windows I believe?. What were the interior panels like where the window crank would have exited?, were the vent windows there? Thanks
wildbill
Old Bronco Guy
:p :p :p You could get them with soft doors but not hard ones also soft top.:p :p :p Bill %) :cool: ;D
josimps2
From 66-68 the window frames were removable. Rather than being welded to the door they were just bolted in, so this may be what you are talking about. You could take out the entire window frame and just have the door. You could probably do a search for removable window frames or something similar and find some threads on it.
68 EB
Fort Atkinson, WI
I was told by 2 different guys that my 66 Roadster was ordered with doors from the factory I assumed that meant steel doors but I could be and probably am wrong!
broncorick
broncorick
Doors,
There was an option with steel doors, my question is what did the panel inside the door look like--was there an empty hole wher the normal window crank have gone??, Also from what I see there were no vent windows present since that would be included in the frame. So really i guess my overall query is what did the inside panel look like--was there a metal or rubber plug, or was it a different stamping-Thanks!
Tito
CB Fire Starter
Bakersfield, CA
From the couple I have seen like dealercut66 his has the regular door and steel panels inside, the upper frames were just bolt in, etc. so you could remove the frame and vent if desired. I dont think the door was sealed up any different than the wagon and half cab steel doors.
broncorick
broncorick
So was there a hole in the insert where the window crank comes through, or was it plugged or not stamped out??
77Bronco636
If the roadster had hard doors on it, they would be the same doors as the half cab or the wagon. The door panels would have been the same also. The door handles and window cranks would have been installed, as the window frames and glass. Some one may have removed them at some point in time, but nothing is different with the doors or the panels just because they are on a roadster. Hope this helps.
Newby
Thorndale
I think it states on www.roadsteru13.com that the 66's had a windowless optional door. Kind of a half door and no top sort of thing.
Yeah, here ya go.
"The door openings on a Roadster were usually filled with a fiberglass inserts as standard equipment giving that classic contoured sporty Roadster appearance. Dealer installed vinyl doors and a convertible top, available in black or white, were available. Hard doors were available as well with or without glass and frame, thus eliminating the inserts."
Right off the sight
broncohunter
The 67 roadster I used to have, had the regular doors but no windows, window frames, or crank mechanism. It had the door latch mechanism only and it did'nt have any door panels. I bought it used so it could have had the door panels originally and they were taken off but dont think so, I dont remember any clips or scratches where they may have been and the paint was original.
markatherton
windowless doors on 66
I have seen these doors with a rubber plug in them
broncorick
broncorick
Thanks for all of the response. Interesting option. I found that when I tore apart my untouched but very rusty 66 roadster, there were rubber plugs in the hole for the striker plate, with a single bolt to keep the plate from rattling, same with the hinge plates--single bolt to keep them quiet. So that started my search for some sort of a cosmetic or functional plug for the door panel.
Tito
CB Fire Starter
Bakersfield, CA
I think I have something that will help with this thread or at least continue it. Apparently the doors could come without frames but you could order canvas uppers that slipped in and out to match the soft top. I just picked up a NOS set from a Falcon Parts Shop that is closing up and they have part # C6TZ-9620146-A on them. I have started trying to find information on them since I have never seen a set but I am sure some of you hardcore roadster guys can help! Anyways, here are a couple pics of them. I am working on the liturature for it too as the guy had it at home. I should be picking up a full box of 66 truck and Bronco literature, film strips, and records that was sent to the dealers. Anyways, I will keep you guys up to date as I get info.
zombie66
Beaverton, oregon
i can't remember where it was but i saw a removable cap that you could install over the window slot after you rmoved the door windows. i thought it was a cool option but never saw anyone actually using it on theirs.
