Rock Crawlers - Need steering help
Mr Joe
I am running 37's with the stock power steering. When crawling at 500 rpm my steering is nonexistent. I have to put it in neutral and rev it to turn. PITA while sitting offcamber. What should I replace first. I am low on funds until next Spring. Suggestions are welcome!! ;D
evil69
fawkin classy
Athens, GA
Canned ham upgrade.
I guess you could try to find some free or cheap smaller pulleys to turn the pump faster. You could also bump the idle up, but then you will not be crawling as slow.
Mr Joe
Mr Joe
Thanks for the suggestion..... anyone running the pump upgrade along with a pulley swap??
Steve
Grand Junction, CO
I'm running the newer pump, and it's not much better with my 36" tires. A smaller pulley would help some, but that has its pitfalls. The only real thing you can do is have the steering box tapped/drilled and then install hydro assist. It's not cheap, but not terribly expensive either. It's an amazing addition when you do rock crawling with big tires. :cool:
Mr Joe
Mr Joe
Hydro assist is the finish line in my mind....Thanks for the heads-up GJBroncoMan.....
Steve
Grand Junction, CO
One more thing to think about. How many turns is your PS box? Mine is a 4 turn box, and in retrospect, I should have stayed with the 6 turn box for rock crawling. I can tell you that in Moab (REAL sticky rocks) with the front axle locked and my 36" Swampers at 6 psi, it simply wouldn't turn if I wasn't moving. With hydro assist, it turns like the tires are on ice. :cool:
Gummi Bear
Joe,
You're in the same boat as me. Doing a simple NAPA pump, or a OEM type canned ham upgrade, is gonna leave you sad in the future. Here's why:
You need a higher flow pump, and multiple inlets/returns to facilitate your ram and also if you decide to upgrade to hydroboost brakes.
I've decided not to get a pump 'just for now' that I'll replace in a few months to a year, instead I'm planning on getting a setup from PSC. They're a small town company, and there's a boatload of experience with steering goodies. Tom is the proprietor, and a nice guy, really knowledgeable about the EB and our wants and needs as a rockcrawler (yep, he's into that)
www.pscpowersteer.com
Call and talk to him, he'll point you in the right direction, and his prices are competitive (but not cheap). You'll get what you pay for. Most of the 'real' wheelers around here are running his stuff, and so far I've not even heard of a failure (even the nuts running 44's and Rockwells)
Mr Joe
Mr Joe
I have some friends running Tom's stuff... Maybe I'll just park it until next year and save up some $$.
Gummi Bear
I feel your pain. I broke an axle back in August, my rig hasn't moved since. I have decided to keep it off the trails until I get new springs, gears, lockers, steering goodies, shocks, and some decent armour. Springtime is looking good. In the last couple of months, my 17 month old daughter has more time in the drivers seat than I do (she loves to play in the Bronc)
Mr Joe
Mr Joe
Does anyone know if my existing Borg shaft can be retained with the PSC setup?
I looked at the DIY article....pretty cool.
tonto
I fully endorse ram assist, for the exact reasons you’re having problems with out it.
When you do the ram assist you will need to get a pump that flows more GPM and has higher pressure, mine tested @ 1400 psi / 3 1/8 GPM, when figuring out how much of a stroke you need a ram to have, have your tires forward and mark a vertical line on the tie rod and directly behind it on the axle housing and turn the wheels side to side and measure how far the line on the tie rod travels in each direction from the line on the axle housing, it’s usually approx. 4” in both directions and between 8” & 9”ss of stroke for the ram, for an Early Bronco.
Also start figuring out now where to mount the ram, and figuring out how to build the bracket to mount it to the axle and tie rod.
Just be aware of the power of the ram, I can have my tire against a rock and turn my steering wheel and push my self away from the rock with the turning of the tire, with little effort, which can lead to damage of a tie rod, knuckle or rim and tire, just be aware and you should be fine.
Here’s some pic’s of mine and the one I copied.
tonto
brut69 said:
"REDNECK RAM" from westtexasoffroad.
Now I’ll have to endorse my favorite box builder and the first guy to start making ram assist as far as I know, these guys make there meat & potatoes from building the pump & box’s for the winning NASCAR teams.
I wouldn’t use anyone else.
Lee Mfg.
11661 Pendleton st.
Sun Valley, Ca. 91352-2502
818-768-0371
Ask to talk to Tom Lee.
Mr Joe
Mr Joe
Tonto: That's the exact location on the diff that I was just trying to visualize ;D I'm guessing the brackets are all homemade?
I have heard some things about Redneck Ram....some good, some bad.
Bart
Buffalo Gap, Texas
Hey Tonto, interesting pictures, but could you please explain the leaf spring in the third picture. All wheel steering perhaps (in a eb)? LOL
