Rock Ski Install Discussion
bronco t
San Diego CA
Does anybody have the link to the discussion on CB on installing the WH Rock Ski's? I know I saw it last year, but cannot find it using the CB search.
Thanks in advance.
bronco t
bronco t
San Diego CA
Thanks TNCowboy... those help, but there was an discussion, just last, year that talked about a few installation methods using rivnuts, screws, drilling, frame tie-in, draining, etc...
JeepGuy
Pics of my install in this one. Almost done... then the honey-do construction projects got fired back up.
I used Nut Zerts on the Rocker Panels, inside and out. Pretty easy to do. I'll be through bolting the skis to the front and rear panels. Once everything is done I'll probably due some welds on the underside to re-enforce everything and make sure if I bounce off a rock it has a little better bite. No idea if it's needed... but I figure it can't hurt.
https://classicbroncos.com/forums/showthread.php?t=306739
