need help with BC Rock Ski install
hammer
Hey Guys,
I'm installing the 1/8" skis. The issue I have is with the three stainless screws that hold the ski to the rocker in the middle. I started the first side and two went in okay but the third isn't holding and just spinning. I suppose I could go get bigger screws and try again but I was thinking of taking a hole saw, cutting three holes on the back side of the rocker so i could get a socket in there and then bolting them up. Then I'd cover the holes on the backside with some rubber grommets. What do you think of this? Not crazy about cutting unnecessary holes in my tub as I spent a year making it perfect but I see it as my best option. I aslo see getting a nut in there a huge PITA. I've never used rivnuts before, not sure if that's and option as well.
Hal9000
Flagstaff, AZ
You could always use pop rivets. Easy to install, no stripped threads or loosening screws over time, and simple to drill out if you need to remove the rocker in the future
trailpsycho
Hey Guys,
You could do as you mentioned with the hole-saw and use the grommet. No reason it wouldnt work.
I used riv-nuts...maybe 8 or 9 on the outside and a similar number on the inner-under rocker...of course I am not running BC's skis, I am running the Rocker Rappers (1/4" SS outers and 3/16" SS inner-lockers) from theBroncoRanch....but a similar concept with similar mounting. http://www.mcmaster.com/#stainless-steel-rivet-nuts/=66tp9n
They arent going anywhere. The M6 is equivalent to 1/4 " in thickness of the bolt. I did have one rivetnut that I coulldnt get seated, so I ordered the next size up and was successful to get it seated and use an M8 for that one hole (its on the underside, so its out-o-sight out-o-mind). I was able to find a long enough M6 and M8 Grade 10 bolt and nuts at a quality hardware store to use as the rivet-nut tool. Some were tricky to get started, but once they grab, they are in there solid. I would still not over torque the mounting bolts...get them all in and semi-tight and then go through a sequence...use anti-sieze and rock-it-out.
chuck
Ingram, Texas
Did you use a awl or did you use a drill to make the screw holes? A little late now but I was wondering. I have twisted screw heads off using an awl and not had them come loose. Rather than cutting a hole you might use a toggle bolt.
hammer
hammer
I used a drill. I know the instructions said to use an awl but I was afraid of caving in my rockers with a nice big dent if i started smacking an awl into them. And now I guess this is what I got for not following instructions. I'm gonna try rivnuts today.
