Rocker arm stud issue
Mac2Night
I have researched all the old threads on this (they were very helpful) but I still have a quick question about my situation.
Here's the history: Bought the EB almost a year ago and it ran fine; Had a rocker arm come loose (nut split) but repaired it and no issues; About 500 miles ago it started smoking on me but runs stong with good-fair oil pressure;
This weekend, I pulled the driver's side valve cover and found that one of my rocker arms was sitting sideways on the spring and that the rocker arm stud was sitting slightly higher than all the others. It still is tight, but as a quick fix, I added some washers on top of the rocker arm, put the nut back on and tightened it all back up. Lifter not collapsed and the valve/pushrod/lifter all seem to work fine and the oil pressure increased and it runs fine but still smokes.
My mechanic friend told me that I should run it for a while and the smoking will clear up, but it really smokes a lot. What do any of you think about all this?
I realize I need to pull the heads and have the studs replaced as a longterm fix, but I would like to see if the smoking clears up with the valve working properly before pulling everything apart again.
Thanks for any advice you can lend.
Mac
mr incredible
sounds like the valve guides also need a bit of attention , the stud will eventually come out ,,, as most of the press in studs do ,,, especially if you are running a bit bigger cam ,,,
also , the smoking might be caused from that cylinder , pulling oil up past the rings , due to that valve not opening in time , it just might clear out ... after a while ,,, you might up the heat range on your plugs , to see if it helps burn it out ,,
One way to fix it is to tap the stud down and drill the base and install a roll pin through the stud boss through the side of the stud. another way is to pull the stud and tap the hole 7/16-14 and screw in a small block chevy stock stud. i believe from a 327 it has no nut on the stud. You will need to use a posi lock nut on top to hold valve adjustment as there is no stop shoulder on the stud. This is a comon retrofit for screw in studs with no guideplates. You do not machine the top of the stud base with these unless you use guide plates which you dont need with stock rail type rockers. You can tap these on the head while the engine is in the truck if you had to and were very careful. There is no drilling just tapping the existing hole. You just have to pull the stud first.
As for your smoking check the drainback holes in the head and make sure they are not partially blocked allowing the oil to back up and suck down the valve guides. Also if you have an automatic check the vacuum modulator and its vacuum line. it will suck oil from the tranny if you have a leaky diaprham.
it is not normal for an engine to split a valve adjustment nut nor is it normal for them to lift a stud since this engine is not of your devise I would check to make sure you dont have coil bind at maxium valve lift thus overloading the studs.
vuke
Red Bank, NJ
beat me to it. After my rebuild a few years back I had a stud pull out on me (probably the new cam and high RPM on the freeway), it made a ton of noise. I ended up putting in screw in studs to eliminate the problem, haven't had any problems since.
