rocker arm stud
widowmaker77
hey guys i instaled a new set of lifters on my bronco. was tightning up the rocker arm nuts and one of them had bad threads i guess because the threads stripped before i even torqued them. so my question is does anyone know what thread size those studs are because a 9/16 wrench fits the nut but the threads are not 3/8 or 5/16 as ive tried die nuts for both of those sizes. how hard is it to pull the stud out and install a screw in type if I cant fix the threads? my bronco is a 77 but if i remember right the motor is a reman 79 302
bpr
Alabama
5/16" 24 tpi (fine thread). I would try to fix threads first. You can pull the stud and press in a new one. You would need to pull the head to thread and tap.
widowmaker77
widowmaker77
thanks on the thread size. ive read to install screw in type there is no drilling you just tap the hole the size it is. i dont remember what size tap it said to use but since there isnt any drilling couldnt it be done without pulling the head?
broncnaz
If its a 79 engine and has studs then it probably has earlier heads as usually 77 and later engines used pedastal type rocker arms. that said ditto on the threads being 5/16 x24. And usually you'll get the same press in type stud. Almost all the screw in type will require machine work, guide plates and hardened pushrods to be used. There may be some screw in type stud that are the positive stop type that could be used and only require tapping the head. but its been a long time since I've seen any of them but they could still be out there.
If you know what your doing you need to pull the stud and tap the stud hole to 7/16- 14. You will not have to drill the hole as the hole for the stud is the right size for the tapping. If you tap the hole crooked you scrap the head so it is not a job to be taken lightly. Then you need to install the small block chevy screw in studs without the integeral nut. You will now have to use a posi lock nut to maintain the proper lifter adjustment since you will loose the positive locking shoulder you have on your current studs. You need the studs that have a 7/16-14 lower thread and a 5/16-24 upper thread. Dont use the more common 7/16-14 lower with the 3/8-24 upper thread as your rockers wont work with them.
My first chouce for this repair would be to re chase the current stud with a 5/16-24 die and use a posi lock nut if it will hold. Second choice would be to pull the stud and replace it with a standard stud. If all else fails then it would be to tap the stud hole and go from there.
widowmaker77
widowmaker77
Thanks for the help guys. I had tried a 5/16 24 die nut yesterday but it didn't seem to fit so instead of taping it with a hammer while turning first I decided to post here. So after I got home. From work I chased the threads and installed a new 5/16 24 torque lock nut. Thanks again!
