Rocker Panel
Wyattman2015
Hi
I am new to the group. I need to replace my rocker panels and want to know can I just replace the lower portion of the rocker panel ?
Thank you
SteveL
Huge chevy guy
Hawthorne ca
Depending if you're building the bronco for off road you could just cover the rockers with 1/4" rock skis.
Timmy390
Conway, AR
Hi Tim
Thanks for your response. Any chance you can let me know where to get started. I have the rocker panels in one piece and I will take them apart but if you could tell me how to take the bottom piece off that would be great !
Just got home from a deer hunt.
To remove the old rocker you have to drill out 30 plus spot welds. To attach I drilled the rocker with holes and plug welded them in.
I'll try and dig up some pics
Tim
W
Wyattman2015
Tim
Thanks Tim much appreciated. Would love to see the pictures. Thanks again and hope the Deer Hunt was successful !
Timmy390
Conway, AR
So found my old pics......Like most projects on my Bronco....once I opened things up I fond MORE rust issues and the job got bigger than planed.
Got a bit carried away with the spot welder.....It was my first time and didn't know what I really doing
Tim
Timmy390
Conway, AR
And the rest.....
Tim
Timmy390
Conway, AR
I used the Harbor Freight spot weld cutter......Use a punch to center the weld you want to cut.....go slow and try not to cut through like I did in several places. Side #2 went much easier. Felt like a pro after learning all the "don't do's" on side #1 LOL
Tim
bronkenn
Bronco Guy
Southeast Ohio
Hi Tim
If you don't need to replace the inner rocker you can get just the outers and save yourself some time not cutting the new ones apart.
