Roll Cage Kit
kuch68
Waterford, MI
Does anyone know of a family style roll cage kit that has extra length added to the end of the tie in points in order to route through the floor and tie into the frame. Most of the kits have the steel mounting plates.
thanks in advance
Josh
crawln68
Contact "Crab" on this site. He can build one any way you want it. And great prices too. ;)
Socal Tom
San Diego, CA
thanks in advance
Josh
Most of the time you don't want to just go through the body to the frame. It's better to bolt the foot plates, to another set of foot plates that are attached to the frame. You should also include a bushing in the connection to reduce the vibration that the frame would apply to the body. Something like this.
Complete off road tie into frame kit
SaddleUp
Vancouver, WA
The tie in pints are nomally separate pieces bolted to the feet of the roll cage. I.E. With the body sandwiched between them. As was mentioned in the previous post the tie ins should have bushings as well. The reason for the bushings is to allow a small amount of flex before it starts work hardening and warping the body where it connects to it. (It is the same reason bushings are used between the frame and body) If you do go through the body and tie directly to the frame then you need to be sure the holes going through the body are large enough to allow the body and frame to flex. Figure at least 1/4" of gap around the tubing. This of course creates a large breeze though in the winter which is why it is not very common to go that route.
crab
As Saddle Up mentioned you will need to make the holes in your floor at least 1/2" bigger diameter then the cage tubing. Another problem woould be that most cages sit on structual members under the floor. Once you cut through these, mainly the front floor support, you are going to loose a lot of body support expecially in the front door pillars and tailgate pillars. Yes we can build it, I just wouldn't recommend it unless you plan on going total tube frame and support the body a little better. You would be better off going with a cage with frame tie ins that are bushed (No, we still don't have them ready). Just my .02cents, I know how easy it is to get gung ho on a project and have someone try to talk you out of it.
Crab
crawln68
:( Nothing yet, huh? :( I was just about to call you to find out if you had these ready yet. ;D
crab
If I wasn't the one trying to sell the product, I'd be pi$$ed by now :mad: ;D
NeverSatisfied
Spring, TX
Mike at completeoffroad.com sells a nice cage with both main hoop and front hoop tie-ins available that utilize bushing isolators. I run this setup and it's great. I have pictures of the cage in my gallery, but I don't have any shots of the tie-ins.
his email is mike@completeoffroad.com
K
kuch68
Waterford, MI
These maybe a lot of stupid questions but I have to ask. To give some background I am pretty much redoing most of the body (front/rear floor pans, cowl, rockers, quarters, etc) with new sheet metal. The rig is being built for a nice summer driver, mild trail capability (something like fins and things, hell's revenge (w/o hell's gate)...) which would lessen the chance for body damage. Still want to be safe as possible though.
1. if I need .5 inch clearance on each side of the bar, and my tie in member is 90 degrees to the roll cage tubing, that would mean my tie in points could translate a total on 1" vertical motion. Does the bushing completely dissipate this vertical translation? If not, I would suspect the body would start to deform at all these mounting plates.
2. What is the strength on the double plate method when using bolts? I know the bar will most likely be in compression, but if there is side forces aren't all the mounting points in double shear?
Summary, what I am looking for is the best protection I can buy without messing up the body more than the holes that are required to mount it.
thanks again for your help guys...
Josh
SaddleUp
Vancouver, WA
Josh
1: No we said 1/4" on each side of the bar which makes the hole diameter 1/2" larger than the tube diameter. This translates to 1/4" of horizontal shift of the body during flex before it can connect with the bar. If you don't think the frame and body both flex this much already then you haven't been on the trails much. Once you add tie ins this will stiffen up the connection between the frame and body some which will make them flex less. Especially the body since the cage will add a lot of strength to it if it is bolted to it properly. (Plates on both sides of the mounting points that are at least 4" square and 1/4" thick with at least 4 - 3/8" grade 8 bolts on each one is usually what is required by racing sanctions) In the end this results in less flex of the body which means it will be less likely to get warped. The bushings at the frame are to allow some amount of flex between the frame and the body. You could remove all of the bushings in the body mounts and then skip the bushings which would make the frame and body a solid unit but that would also transmit a lot of vibrations up into the body from the drivetrain.
2:As mentioned most racing sanctions require 4" square plates that are 1/4" thick with 4 - 3/8" bolts when the cage is bolted to the body. Keep in mind that while it is suggested that the cage be tied into the frame most of the racing sanctions do not require it. (4" plates already make the cage to body connection stronger than the connection between the frame and body if the structure of the body is sound)
On the subject of making tie ins I've found the right combination for the bushings. The rear spring urethane eye bushings are 1 1/4" in diameter. 1 1/2" x .120 dom tubing has an ID of just a few thousands of an inch larger than that. (About .010) When I make my frame tie ins I will be using EB rear spring bushings with the 1 1/2" x .120 DOM tubing at the bushing. For the brackets on the frame I will use 2" x 1/4" angle iron. All I need to do from there is make a connection between that and the plates under mine with dom tubing. It will be identical to the frame connection I made in the pic below when I built my cross member.
K
kuch68
Waterford, MI
thanks for the info....that answers my questions. I just wanted to make sure I was doing it correct the first time, and not have to redo it later. With this setup, the bushings dampen out as much vibration as the body bushings do already?
thanks again.
SaddleUp
Vancouver, WA
thanks again.
Theoretically it should since they are both made out of the same material if you also run urethan body mounts. I don't have mine tied to the frame yet so I can't speak from personal experience, just from the previous research I've done on it in anticipation of doing mine that way.
crab
kuch68 said:
Crab.....How many years long is the waiting list currently for your family cages?
thanks
.125 years ;D
We just pumped out a dozen cages and finishing up a couple more. We are regrouping in a temporary shop until the new shop gets built. It will be about two weeks until we take any new orders. Let me know then if you are still interested and I will get you an estimated wait time.
Crab
