Roll cage welding - multiple passes necessary?
Nobody
Stanwood
Weld up some pieces of tube, then beat the snot out of it with a sledge hammer, jump up and down on it, run it over with the bronco, whatever it takes until you are satified with your welds. If you are a half decent welder, there should be more than enough surface area to keep things stuck together. If you need some more insurance, add some gussets.
And I agree with the others, 220V is really the only way to go.
DanWheeler
DanWheeler
Kirkland, WA
thanks guys, sounds like the consensus is the welds are *probably* ok but that probably isn't good enough for a cage which i agree with. I'm gonna grind them down and pass over again with a 220 welder.
thanks for all the suggestions
broncow72
Village Idiot
Spring,TX.
Well, you can see the blueing on the front passenger side that has been spoken about and not so much on the drivers side. But that was what I was getting at.
Skiddy
I think you will be ok, main thing that I see wrong is some cold lap and a little undercut. If you put another pass on it you will be golden and you won't have anymore doubts. we have a saying here "if in doubt grind it out";D please sumbit samples for xray and bend tests j/k;D
