needabronco
I scored a really clean 96' roller cam 351 over the weekend. I'm gathering some ideas for the upcoming build. I'm most likely looking into a mild to medium build on a stock 351 bottom end. I'm not even sure this block will need to be bored.
I'd like to hear what you guys would recommend for a roller cam and of course heads. I already have a pair of rebuilt GT40 heads and the stock 351 heads that only need minor clean up. I'm not completely ruling out buying new heads but I can't afford high dollar heads or the snowball affect that follows that. And new heads will likely kill the rest of the budget for other goodies (and rebuilding the 170 in my 66').
I'll be running efi with an A9P computer, lightning lower, explorer upper, explorer MAF and throttle body with 19lb injectors, WH shorty headers and a single 2.5" exhaust. The rest of the drivetrain is an AOD, 4.88's and 35"s. At 70 MPH I turn 2200 RPM's which is where I want my torque to be.
I want torque right off idle but want to still make power higher than 4,000 RPM's, I wouldn't mind upping the compression, but don't want to go any higher than 9.5:1 or so.
So lets hear your ideas!
