bdog9seclx
- Apr 28, 2014
- 183
All other gears shift easily. The truck has sat with minimal driving from the original owner. its a 74. But everytime I shift into reverse it sounds like bad thud and metal on metal. Every other gear is smooth and nothing like reverse. Since I just bought this. Im sure many would recommend getting all the fluids changed on the rear gear transfer case and transmission? oil has been changed. Any other suggestion for just buying it on what to refresh? also vacuum line i read could be part of problem
thanks in advance for the help
Ive read to change the idle. but there is no tach so id be going blind also i am a virgin with a carb. IM a mustang guy with fuel injection knowledge only. But know motors enough to learn...but prob also enough to maybe not do it 100% correctly. Idle is on drivers side of carb correct?
Anyways just thought you guys would be able to help
thanks
thanks
