Rumble from exhaust not the same...
airbur
Castle Pines, CO
Standing behind my Bronco today (contemplating my @#$&*! lean) I noticed that the rumble from the driver's side exhaust pipe sounds quite a bit different that the passenger side. I have a dual setup with twin hooker competition mufflers.
It almost sounds to me like the driver's side is miss firing or a cylinder is dead. I don't have experience troubleshooting this type of thing. Looking for ideas. I could post a video of the sound difference.
Thanks.
mavereq
when is the last time you pulled your plugs and compared them to eachother. is one different than the others?
And have you adjusted the separate idle-air mixture screws on the carb lately?
Miker
check spark to the plugs then consider getting the tool/guage that you screw into your spark plug hole one at time to check for compression in each cylinder by turn over the motor with the starter (pull ignition wire so it won't start) I did this for the same reason as you and found a burnt valve with no compression. Just another idea,,
Scoop
Bronco Old Fart
Cuchara, CO
Carb should not make a difference side to side. Both (or all 4!) bbls feed both heads equally.
As Miker said, I'd look at the plugs then run a compression check. Also check your headers/manifolds and exhaust for leaks.
blainebrazil
Santa Rosa
I had the same problem years ago on my 76. It had some sort of emissions/butterfly looking valve on the end of the exhaust manifold. valves were shut when the engine was cold and opened when warmed up. My passenger side valve stuck shut not allowing the exaust to flow freely out that side. tailpipes definatly sounded different from eachother. The manifold got so hot it cracked the cast iron. switched to headers after that.
airbur
airbur
Castle Pines, CO
So I replaced all the plugs and wires (I broke one off trying to remove it) and it definitely idles better now....but the sound difference remains the same. I'm thinking exhaust leak now. I will most likely be in the manifold as all the pipes are new. Is there an easy way to detect a leak in the exhaust manifold?
scbronco
Sumter, SC
you still need to do a compression check before you start chasing an exhaust leak... like was already stated, it could be a valve...
garberz
Bronco Influencer
Conejo Valley, Ca.
A quick way to check for a dead cylinder, is to pull the coil wire and crank the starter. If you notice a skip in the rhythm of the engine turning, you have low compression in one or more cylinders.
