If your console doesn't come up all the way to the dash, you could:
1) run it to the xfer case shifter hole underneath and then from there.
2) run it all the way underneath with a good sealing grommet (I love the seals-it ones) or an old school firewall grommet
3) through cage and then under seats?
4) I'm assuming you have no carpet...otherwise under the carpet is easy, but you could run a low profile cable cover or anything over the top that the wire runs under.
5) build/find a front to your console
If it were me, it would go from underneath or extend the console forward.
