running on three
Jeep Slayer
fort Mohave
I need some fresh ideas on why my 170 is running on just three cyl.
It has a new carb new fule pump and has a pertronix ignitor in it.
only cyl 1,2 and 4 seem to be firing.
any ideas ????
Bryan%)
bronko69er
EB Addict
Renton, WA
When you say "not firing",how or what method did you use to come to this conclution? More details please.
If you mean the plugs aren't fiiring.... what are the condition of the cap rotor wires and plugs?
Jeep Slayer
Jeep Slayer
fort Mohave
Ok here go's , I checked the plug wires with my timing light and only wires 1, 2 and 4 got a flash, then one by one I pulled the plug wires off the spark plugs and got the same thing only 1,2 and 4 made the idle drop.
Checked the cap and rotor and they seem to be fine.
The coil and voltage reg are fairly new.
was thinking it might be the ignitor on the blink
bronko69er
EB Addict
Renton, WA
First you need to confirm that your wires ar good. Try swapping the wires around an see if the same thing happens. If it changes which cyls aren't firing then you know its the wires. I would also try a new cap and rotor being that they arent that expensive. It would seem to me that if your coil/ignitor were not functioning properly it wouldn't happen on the same wire each time, it'd be more random. Maybe the lobes that trip the points are not uniform?????
Jeepster
There are several methods of checking for spark, Take a known good spark plug and known good wire and systematically plug in the combo to each of the 6 terminals of your cap while grounding the plug. If it fires every time look at the wires/plugs in that (bad) cyl. Eliminate the unknown.
Jeep Slayer
Jeep Slayer
fort Mohave
Well I put on a new cap and rotor and still no spark to 3,5,6 cyl I will try checking the wires first thing tomorrow, also checked the charging system and it seems to be working well.
This is what I get for parking her for a year ( so I could afford insurance for my 17 year old daughter) And when I parked her she was running great.
This whole thing started with no fuel to the carb (new fuel pump )
Then after finding a pump that would fit ( off a 70's comit ) as soon as i started her I blew just about every seal on the carb (fuel everywhere )
So seeing that carb was in such bad shape I got a rebuilt at a local carb shop
then I found that the mounting holes on the carb were to small for my 3/8 studs so I had to drill the holes one size bigger. Then come to find that the throttle was a bit different then the one before and I am having problems with the return spring, Anyway thanks for all the help and ideas.
I will continue with my CSI of this case.
Bryan
Jeep Slayer
Jeep Slayer
fort Mohave
Ok so I checked the wires and thay all work when hooked to the known to spark #1.
At this point I can only think it is coming from some sort of glitch in the pertronix unit.
73stallion
Eugene, OR
take the magnet ring in the dizzy and rotate it, see if it fires on different cylinders. i've seen that happen with those units before. call them, they may warranty it for you, their customer service is great.
Jeep Slayer
Jeep Slayer
fort Mohave
Problem solved , Inside the dis under the rotor is a plastic ring that go's onto the dis shaft it has six or eight magnets depending on if you have a six or eight banger. there is suppose to be some tape holding the magnets in place. Well the tape on mine came off along wit three magnets. Called Pertronix and they are sending me out a new ring FOR FREE . Thats what I call customer service.
Also thank for ALL of your input.
Bryan
