Running the brake lines
rflud
Modesto, CA
A few questions -
1. M/C which port goes to what? Small goes to? Large goes to?
2. Anybody using the Wildwood Adjustable P-valve with the drum H-block? Does it goes between the H-block and the rear brakes? If not what is the routing of the hard lines? BTW I'm running front disc and rear drum.
I had a third question but don't remember it now.
lars
Been here awhile
NorCal flatlands
1. Large reservoir is for front brakes, small one is for rear brakes.<br><br>2. I've installed one that way. Yes, it goes in the rear line. Removed the stock line between m/c and h-block, bought new ones with fittings from Napa, one went between m/c (front port, which is for rear brakes) and prop valve, other from prop valve to h-block. Works fine.
Benzo
SF Bay Area
I use the F250 Camper Special M/C with my disc/drum brake setup. My rear brakes would always lock up before the front. (Really scary in the rain on a turn!) I installed the Wilwood P-Valve from Summit Racing inbetween the M/C rear brake port and the H block. It adjusts easily by hand and was simple to install. It took a total of 30 minutes with cutting and double fairing the brake line, installing the P-Valve and bleeding the brakes with help. Adjusting the braking balance was a ride around the block with two stops. One for, I need less pressure to the back still, and the other was a finer adjustment just to make me feel happy. It made all the work I did for the disc swap so much better. I stop great now, were as before without the P-Valve, the rear drums still made my bronco pull to one side or the other. They were grabbing first wiht so much pressure. I am very happy with the $40 Wilwood P-Valve. This is my daily driver and I drive about 25miles each way in major stop and go traffic. I also don't get sidways on trails anymore. :D
R
rflud
Modesto, CA
Cool! I should have my Brakes all taken care of tomorrow. Although I won't be able to test them yet. A few more thing need to get finished first. Wiring, drivelines, tranny linkage....<br><br>The list never seems to get shorter.
lars
Been here awhile
NorCal flatlands
[quote author=WrenchMonkey link=board=5;threadid=12264;start=0#90982 date=1039746404]<br>I use the F250 Camper Special M/C with my disc/drum brake setup. My rear brakes would always lock up before the front. (Really scary in the rain on a turn!) I installed the Wilwood P-Valve from Summit Racing inbetween the M/C rear brake port and the H block. It adjusts easily by hand and was simple to install. It took a total of 30 minutes with cutting and double fairing the brake line, installing the P-Valve and bleeding the brakes with help. Adjusting the braking balance was a ride around the block with two stops. One for, I need less pressure to the back still, and the other was a finer adjustment just to make me feel happy. It made all the work I did for the disc swap so much better. I stop great now, were as before without the P-Valve, the rear drums still made my bronco pull to one side or the other. They were grabbing first wiht so much pressure. I am very happy with the $40 Wilwood P-Valve. This is my daily driver and I drive about 25miles each way in major stop and go traffic. I also don't get sidways on trails anymore. :D<br>[/quote]<br><br>Ya, they work great, don't they? I got lucky- for some reason I didn't need one at all, but I have 4 wheel discs. We didn't have a flare tool to do my friend's, Napa wound up having the exact right length pre-made lines with fittings. It was so easy it was funny. Sure is nice to be able to stop straight!
mrcat88
VacaVILE, CA
I have a Wilwood valve, and I like it too. highly suggested. <br><br>when you run the lines, run the front brake line directly off of the master cylinder, without the H-block, and in the rear line put the Wilwood valve in place of the H-block. Throw the H-block away. it's a peice of crap. <br><br>Mrcat88
