Rust Bullet Idea (question?)
md_lucky_13
Idaho
I noticed the new mass-buy on Rust Bullet, and I have also noticed that the owner is kind enough to come buy and answer questions from time to time. So, first and foremost: thank you!
My question is this:
I know this might sound "cheesy" or "lame," but I have actually seen a couple people do something like this, and have it turn out really well. So it inspired me to ask.
In another thread, we are talking about the color to paint a front bumper. I mentioned that I used a bed-liner spary bottle because of the texture. Well, it has held up great, except for when I bounce a bumper or rocker hard off of something. Then, it tends to peel away, exposing fresh metal.
My idea: take a quart of rust bullet, mix in sand, and hand brush it onto the rocker panel bar I have. I know it sounds crazy, but I have seen a couple of people do it for bed liner with POR-15 (I beleive) and I like the texture it gave. It was basically exactly what I am looking for.
The one thing I am worried about (and this is where my question is coming from) is that this sand may somehow slow down the cure time, or worse, will make so the paint will never cure. If this is too hair-brained, does anyone else have an idea as to how to make it have this texture? I will try to find some links to pictures of people who have done similar ideas (mix sand into a paint for a non-slip bedliner) and hopefully everyone will not think I have lost it.
What does everyone think?
wmish
Annapolis, Maryland
md_lucky_13,
Your not crazy. We do this with boats all the time allthough we use a special silca powder with expoxy and with acrlyic paint. I'm sure your could mix some thing with rust bullet just check with them first to make sure it will cure correctly. I would think rust bullet would be ideal with its adhesion properties. Could be a tech write up. Maybe rust bullet would throw in a free pint to test different methoids and mixtures out.
Bill
POR-15 Depot
Dallas, Texas
This isn't a crazy idea at all. It's being done now with Rust Bullet at This California Recycling Plant on concrete. Yes it makes a GREAT concrete sealer also. First lay down the first coat as directed. 3-4 hours lay down the 2nd coat, Right afterwards sprinkle sand on top so it blends in to the coat and your done. If you want even more protection do the same with a 3rd coat.
This is the sand being scattered over the last coat of Rust Bullet there..
Nope.. No effect..
md_lucky_13
md_lucky_13
Idaho
Perfect. This is something I will be looking into in the near future.
I was planning on using a silica sand, like the 30 mesh or so that you run in a sand gun. I like the idea of a uniform dimension (or close to) that a seperated sand will make.
Thank you!
