Rust Bullet your EB??
BRONCOchild
Anyone in here use Rust Bullet? I'm getting back into the swing of things with "Bertha". She's currently at the mechanics getting some minor issues taken care of. Thanks to all that suggested to look at her timing. Hopefully, the issue with her backfiring will get resolved.
With that said, I'm thinking of using RustBullet on the rear bumper tire carrier I bought. I don't know what brand it is, but it was a bargain at $350 (never used). However, the bumper is in it's raw metal form and not coated with anything, other than the light rust that has been wrapping itself around. Has anyone use RustBullet? Any issues or things I should know about? I've checked out the website and pretty amazed at the end result, but I need testimonials from EB owners.
Once again, thanks for all of you that chime in and have helped me out throughout the years. I'm in no way an expert on my EB, but I do know one thing-I love these little rigs!!
http://www.rustbullet.com/Products/Automotive/Automotive.asp
Devin
Bronco Kineticist
Do a search, plenty have used rust bullet. Most of the reviews that I have seen aren't that good. I put it on my frame, but after reading so many reviews I switched to POR-15 and didn't look back. Some have had good luck with rust bullet, though.
IowaMike
I used it on PO's patches under the hood where inner fenders mate to kick panels. Has held up well so far & that was at least 5 years ago.
Mark
Bronco Klutz
NW Indiana
I think if Los Angeles is dry then you're ok, but it didn't hold up well in my salted roads here.
68rockcrawler
I don't have experience with Rust Bullet but I have used POR-15. POR is not UV stable so it needs a top coat to protect it from the sun. Not sure if Rust Bullet needs a top coat but it would be worth checking in to. POR works great.
Landho
Cypress, TX
I've used both Rust Bullet and and POR-15, and have pretty much gone to exlusively using POR-15...
I just like how durable the POR-15 seems, though it is a biatch to apply with the brush (I use the foam ones, the hair ones always seem to leave hairs in the paint), it smooths out nicely if done correctly. It is VERY difficult to sand. I've been testing out top-coating POR-15 with non-POR-15 paints and this only seems to work without issues if you let it cure for a good 7 days (that's warm and humid 7 days here in Houston, maybe longer if cold and dry). I love being able to POR-15 something, and then bang it around with hardly any worries about it damaging the stuff. YES - you do have to top coat it if there will be sunlight hitting it. I POR-15's my D44 and the sun hitting it for just a few weeks has made it cloudy... no worries, I just top coated it with POR-15 chassis coat and it looks perfect again.
The Rust Bullet seemed a tad bit thinner BUT it would seep in to seams a bit better. Also, I have had better results getting a "smooth finished" looking surface with the Rust Bullet (spray can) - the brush finished Rust Bullet came out pretty crappy... also it just didn't seem to hold up to the bang/dings I would expect it to hold up to.
In both cases, with both paint brands, I've let the stuff cure for over a week - then rough sand with 80-grit - then apply a sandable rattle-can primery, and then top coated and they came out pretty darn nice. The top-coat and primer will scuff off as any normal paint would, but you have to try pretty hard to get the POR-15 off.
my next step is to do it right, and sand-blast and apply SPI Epoxy primer to the bare blasted metal (clean metal with no rust!)...
