- Oct 22, 2001
- 890
I've got a saginaw pump that was used with hydroboost. Now, the truck has stock power brakes and I have an extra line. I was going to just cap the extra line, the top one, believe it's just a return line, no pressure? I had a plastic plug in there with hose clamp and it wasn't quite tight enough, little bit of fluid would leak out. I just put a larger bolt in with clamp, fired it up, no leaks, but it would squeal and pulley would actually stop for a sec when trying to turn wheel. Can I not plug this line?
