Santa came early
57baja
I wanted a little more power so I bought the Trick Flow top end kit. It is nice to see a Made In USA stamp when shelling out 2600 bucks.:)
57baja
57baja
Gave up on the Kenne Bell?
Yes I gave up. I blew a head gasket, and did not want to mess with it. I did a lot of work to make it fit but the motor ran really hot. I should have just taken it somewhere to get it dialed in. I might try a vortech suercharger since the computer tuner I have is more for a centrifigual or turbo style set up. What really was hard was the set up tune sheet I got for a base setting on the tuner. It ran poorly and I could not get it right so after I blew the head gasket the blower sat on the bench for a few months so I sold it.:-[
hammer
That sucks. It had the cool factor for sure. I knew you were struggling to get it dialed in, and I was paying attention as it was on my wish list. Leaning towards a 408 instead. Searching craigslist for a roller windsor truck that I can pick up cheap. Now that the bronco is pretty much done I need a new project.
Mill KNOB
Rock Hill, SC
Nice. Hope that he comes to my House real soon. All I want for my Bronco is nothing like he brought you. Enjoy putting all that On you Bronco.
bell55
Ventura, CA
Baja57, did your KB have the bypass valve? It seems to help with the heat on mine. No intercooler is the big down side to the KB for the 5.0's. Good luck with the new set up.
57baja
57baja
No bypass. I talked to a few Bay Area shops for tuning but most said without an intercooler you really limit the power potential because boost can't go to high with 91 octane. I think the people I talked to just did not want to mess with the older technology. I did not get it because thousands of these blowers are out there and I'm sure most work just fine. I'll update my progress thanks for the encouragement.
hammer
How's the install going? any updates? Im curious as to how you like the package.
TTTGOWYO
Tyler T. - EB Obsessed
Louisville
Where did you buy this package? Looks great, what kind of power are you expecting? Thanks..
broncoitis
That stuff is gonna look, run and sound good! Good luck with the buildup! ;D
hammer
Okay I'm just as bad as my wife. Pestering for an update.
