School Project: Electric Locking Hubs
FBSixtyEight
Oley, PA
Hey all! I am in an engineering class in high school for my senior year that involves a year long design project to solve a problem using CAD software. We will even have the opportunity to go through the patent process if we do well. One idea that came to mind was creating a device that would replace the locking manual hub "cap" that you turn to lock in the hubs with an electric servo that would turn the hubs in for you. Obviously, there cannot be any wiring for the servo because of moving parts, so it would be battery powered. An idea that I had to overcome this shortcoming would be to put in a wire from the alternator to around the rotor/drum backer plate that would make a connection out to the battery of the servo when the truck is stationary at a traffic light, etc. Using a similar setup like a remote controller for a tv or rc car, the servo could then be wireless operated from the cab of the truck at the same time the transfer case is engaged. I will try and take a screenshot of the Autodesk file that I made that shows this design. I was wondering if anyone had input on any ideas to improve the initial design? Also, would you guys be interested in a product like this? I am looking at reliability above all else, so don't think this will be "just another failing auto hub system." If it does not work well, I won't bother making it. Just wanted to know your thoughts, criticism welcome! :)
kholding
Las Vegas, NV
Are you trying to get us to do your homework for you???...Good for you! As for the answer, I have no idea. Good luck.
FBSixtyEight
FBSixtyEight
Oley, PA
No, no, no. :) I was just testing the waters to see if anyone would be interested in the project and has any suggestions. I will definitely be doing the project myself! Haha! The question was more about whether or not you guys would be interested in a product like this.
Wyflyer
I myself would go for automatic hubs before I chose anything electric. I have this love/hate relationship with anything that needs replaceable batteries. Every time i try to find batteries we're out. My wife is no help, she can't explain it either.
But enough of that..
They will have to be as compact as current hubs, have the torque of a pair of vice grips, be water proof, and be stout.
my .02
Arikilen
Clovis, CA
I would look into Ford's vacuum operated actuator used in early/mid 2000's.
A trip to the wrecking yard observing and taking a few apart would give some great ideas. Take pictures!
okie4570
NW OK
Interesting and looking forward to seeing what you come up with. As for now, my automatic /voice command hubs work flawless. "kids, hubs, now!" :p
I would look down the path of multi clutch packs like used in automatic transmission clutches using electric clutch technology like air conditioner in cars for application force.
Still in use today.
The hub isn't a great place for anything electronic. You have grease, and often (not desired) moisture. Continuous heat from the bearings and spike heat loads from the brakes. You probably have no idea what kind of G loads you can see at the spindle. I know people who have done some chassis work and told me a big pothole can spike 1,000Gs at the knuckle (and not hurt the vehicle). And that isn't dealing with the 1,000 RPM of the spinning hub at highway speeds. Trying to package any electromagnetic type of actuation (motor, solenoid) inside the confines of a hub and have enough force to actually move the locking mechanism won't pan out. It is also a vulnerable area, plenty of hubs have rock rash on them. Don't even think of adding bulk to add packaging space.
OK, so you really still want to do this. Look at Mile Marker hubs. They have a pre-selector in the knob. You turn the knob in or out and it will turn. Locking and the inner splines don't line up, the knob compresses a spring and when the spines line up the spring pops the hub in. Same for coming out. Just turn to free and when the pressure is off the axle shaft another spring will slip the engagement splines apart. That would be better for having a motor actuate the hub and not run into issues of the mechanism not wanting to turn and how to handle that.
Come to think of it, there is a form of electric axle disconnect that has been on the market for decades. Axle disconnect on the long side shaft. Some have been vacuum, GM did a thermal actuator that used a heating element and a substance that expanded in the heat, but some have been electric. Even used on new IFS trucks.
The magnetic clutch pack won't work. There is no way to get enough clutch frictions in the limited confines of a hub. Especially considering the exceptionally high torque loads that are seen on an axle shaft.
Explorer
Raphine, Virginia
A lot of issues to address as already mentioned. I would consider electric shift for a Dana 20 as a more practical project. Many people have trouble with the "J" shift pattern. An electric "twin stick" is something I think would actually be marketable.
roundhouse
The electric keypad locks on residential house doors are battery powered and pretty strong
Combined with the mile marker pre loaded hub might work by remote control
FBSixtyEight
FBSixtyEight
Oley, PA
Thank you for all the replies, everyone! I like the mile marker hub, I can't remember seeing that before. That will be very helpful to see how that mechanism works. That idea with the electric keypad locks is an interesting idea, I will have to research more on that one. The durability is something I would really like to address. I don't know if I am shooting for rock crawler worthy, but road and occasional offroad would be nice. I will update my progress as I go along so you guys can comment with any new ideas or potential problems I should address. Thanks again! - Ben
