Sealant for firewall
KeithKinPhx
Hi. I’m restoring my 68 and am starting to mount equipment to the firewall such as the heater box, accelerator cable and brake cable. Given the rust I’ve found and removed on my floor pans and under the dash I would like to seal up all the openings as weather tight as possible. Not to mention keeping engine fumes out too.
I have the weather stripping kits but there as still small gaps where the opening for the heater box goes thru the wall. Same for the accelerator assembly.
I just painted the bay a beautiful peacock blue, purchased a stainless steel bolt kit and don’t want to ruin it with big blobs of black goo. Kind of would ruin the look if you know what I mean.
What is recommended to seal the gaps? Should it be applied from the cab side rather than the engine bay?
I appreciate that I may be over thinking this but after all the hours and money to get it this far, jacking it up at this stage would be a shame/crime.
Thanks, Keith
Hozr
Rogue Valley, OR
Seeing as you are in Phoenix and water won't be tooooo much of an issue. I would try to source (neoprene) rubber firewall grommets in the appropriate sizes.
If they are the screw on type Mounting them from the engine side may be possible in a few spots but may not be practical.
I have a few of the Seals-It screw on split type that are really nice.
Steve83
Tacky Tape, FTW.
(phone app link)
If it gets really scorching-hot for a long time, it will sag slightly. But it never hardens or degrades. If it ever gets dirty, simply stretching & kneading it will restore its adhesion (repeatedly indefinitely). And it can be peeled off & then used to remove any of its own residue like chewing gum (which is what it feels like). It has no odor, and is flame-resistant.
904Bronco
San Martin, CA
Well from the factory they used a material like plumbers putty, which I have used...
I have made round/small sections of dynamat and placed the foll sections out when doing sealing around the heater mounting holes...
AZ73
I put dynamat against the inside of the firewall and cut holes in it to fit stuff through. For clutch brake and throttle I used the flexible boots
71broncman
Maysville, Ky
Tacky Tape, FTW.
(phone app link)
This is what I used to reseal the heater/air ducts, steering column boot, and a few other things. I used 3M strip caulk (black), 3M Dynatron (gray), and 3M urethane (black or gray depending on location). The seam tape I used is for sealing seams on metal roofs.
Mark.
K
KeithKinPhx
Ordered some Tacky Tape off of eBay. I have some Dynamat left over from a prior job I can use on the inside.
I think the will get me going.
Thanks to everyone who replied.
