Sheehanigans
Newbie
Hey all,
Finally got my recently acquired bronco fixed enough to go drive it and find more things to fix. I'm hunting down a grinding/whirring noise that occurs on deceleration while in gear. Acceleration sounds good, and coasting with a little gas is good, but as soon as I let off the gas and it starts engine braking, it makes an uncomfortable racket that sounds like its coming from the transmission tunnel or the floorboards. Clutch in and the noise goes away.
While putting in new brake lines and hoses, I realized my rear diff breather bolt was blocked and the hole was rusted shut. It let out a hiss of pressure as I unscrewed it, even though the truck was cold and hadn't moved in weeks. Hmm...
Cleaned out the breather and put it back on, but now I'm thinking the rear gears are in need of some help due to the pressure and who knows what else has gotten in there.
Could this be the source of my noise? Research so far says that a deceleration noise from the rear end indicates a problem with the pinion bearing. But they describe it as a howling, where mine seems more mechanical grinding. Or could this noise be coming from a similarly neglected transmission? If it is the rear, how difficult is a drain/clean/relube?
