md_lucky_13
Okay, I promised that I would get this hammered out today, so here it is. I will try to contact Admin and maybe get it to be an official tech-write in the near future, but for now this will have to work.
Here is the dilemma we all face. If you remove the original hard top, you are making it much easier for the bad-guys to get in and steal your stuff. There are thousands of different tricks that can slow or stop a theft, but one of the tried and true methods will always be the car-alarm.
After removing my top, I became paranoid about losing my valuables inside. I have never been afraid of someone actually stealing my bronco; I have several cut-off switches and tricks that would prevent that. However, this would not stop them from stealing my tires and rims (just price a set of 35" MTRs), my stereo, my hi-lift jack and tools, or anything else that isn't permanently bolted into place.
I found a fairly in-expensive security system from JBM technologies, a division called "Bull Dog Security." (www.bulldogsecurity.com). The model I chose was the 7002PRO, which came with remotes, unit, stickers, and all the instructions it would take to install it: http://www.bulldogsecurity.com/bdnew/proseriesalarmpage.htm
Once receiving the unit, I became fully aware that it had more options then any bronco owner would ever be able to use. However, it had 2 very vital options.
A: A shock sensor, that will chirp the alarm if the vehicle is struck (or, if someone climbs into it looking for a cheap stereo)
B: A "zone sensor" optional addition. This allows you to create "zones" that if the system notices anyone’s hand reaching inside, will chirp the alarm.
The first thing I went to work on was a location for the actual alarm horn. According to their directions, the best location is up high, away from wire cutters and facing down at the ground. Due to this being an off-road application, I wanted to keep it in the cleanest and safest location possible. I chose the driver side fire-wall, where it was safe from heat, water, and most elements:
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/horn.jpg
The next step was to find a good location for the control box. I had plenty of room under the dash on the driver side, so I decided to locate it there. I then dove into the wiring. The directions were very clear, and I had no difficulty wiring in the wires that I would use. Disconnect the battery for a safer install. Don't be afraid if you have a bunch of left-over wires; most of them are for things like "dome-lights" and automatic electric locks.
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/box.jpg
Most of the wires you will use are the following:
1 Constantly "Hot" wire (always has electricity)
1 Key-on hot wire (only has electricity when the key is on)
The Parking Lights wire (for turn signals, they flash when you press the button)
Open door sensor wire. -I will get to this later.
After you have wired in the box, check that everything is working. Wire the antenna in as high as possible, allowing for a further distance and signal:
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/antenna.jpg
Next, wire in your flashing LED. This lets you (and the bad-guys) know that there is an alarm system, and it is armed. A lot of times the simple little flashing light will be enough to scare away potential armature thieves.
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/blinker.jpg
One of the last things I wired in was the door sensing wire. This was the only part of the install that took a little custom fabrication. This until allows for two types of sensors:
1: when the door is open, it gets a shot of 12v (connects to a specified wire)
2: when the door is open, it becomes grounded (connects to a different wire)
The system will not operate properly if one of these is not connected. I chose to use the ground system, because it seemed much easier to create a ground then to create a hot wire.
I went down to Napa and found a small door-opening unit. It was only described in their books as "Bus Style Door Jam Sensor." It is a very simple unit that has two wires coming to it. When the small tap is open, it allows the wires to touch a common copper end, creating a closed circuit. When the tap is pushed close (when you close your door) it separates the wires from the copper, between a plastic tap. This removes the ground. It was about $4 at Napa, and easy to install. Sorry for the blurry picture. The wire to the right of it is the ground:
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/door.jpg
The other wires are for future options, such as remote start (for a $10 relay, I think that would be a cool bragging right for a bronco.. more to come on that in the future), the "zones" described above, and other options.
The system comes with two remotes, pictured here:
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/remote.jpg
Overall, the install was rather easy, and anyone with a little electrical knowledge should have no problem. The key is to take your time, route the wires correctly, and do it right the first time. Lets not forget why we are doing it, there is a lot of money tied up in some simple electronics......
http://www.angelfire.com/extreme4/lucky_13_bronco/classicbroncos/alarm/radio.jpg
Scale of 1-5, I would rate this a 3+. The thought of wiring may intimidate some, but over-all was simple and easy to follow.
Tools Needed:
Alarm system
Test light (or ohm meter, I prefer the simple "light on, light off")
Wire crimping/cutting tools
Wire connectors
Drill
Wire loom
Time Needed:
Approximately 5 hours
Tools Needed:
Alarm system
Wire connectors
Drill
Wire loom
Time Needed:
