Uh..I think we're getting a little bit off topic Mad..but hey!..its your thread.;D
30 or 33 spline axles? 30
What degree c-bushings and type radius arms? 7-degree bushings with 14" extended arms that have approx 2 degrees built in to them.
Did you have to rotate the knuckles for caster? Nope.
And where did you remove the 5"?
2 1/2" inches on both sides or 5" on the passenger side?
zactly 5.1" taken out of pass side tube, makes EB inners fit perfect both sides. The outers will depend on which hardware you uses..mine are the 9.72" outers for the F-250 spindle/brake/knuckles I'm running. 9.72" for F-150 5-lug stuf too.
I not sure what the differences in axle length is between the EB D44 and the FS HP D44.
I thought it was 6".
See above.
I take it that the solenoid is mounted high in the engine compartment, right?
I know you play in the mud and I do too, I would be worried about submerging that thing....
Mine is mounted right on my air tank..which is sitting on top of my pass side front fender well. However, solenoids don't much care about submergence either, as long as the connection is watertight.
Thanks for answering my questions,
madgyver
Yr more than welcome
Bill
BTW. I'm still trying to find out push rod length for the Clevor....
Buy/borrow a pushrod length checker.
