Sewing tech: DIY extended bikini top
gddyap
Mtn View, CA
I'm extending my roll cage to be a family cage so the 2yo can go along on trail rides. I have an old Kayline bikini top that only covers the front passengers so I needed a solution to keep my son out of the sun. I started by getting a $17 canvas drop cloth from Harbor Freight and cut it to size to fit the bikini extrusion.
My wife set up her sewing machine and I went to town sewing up the edge so it wouldn't fray. Being a guy and not too worried about color matching, I used whatever thread was set up in the machine which was dark blue. I then needed something to secure the fabric in the c-shaped groove of the extrusion. I found some poly tubing I had and sewed that in. You could also use a piece of rope as long as it is slightly smaller in diameter than the groove.
I installed the new fabric with the extrusion onto the bronco to measure for length. I cut the rear with an arch like the Kayline bikini top for rear visibility which doesn't really matter when you've got a 37 hanging off your bumper anyway.
Next, I folded the corners over to double the material for strength and installed grommets. In the grommets I knotted in a mini-bungee. The mini-bungee hooks into one of the holes in the hard top stake pocket.
Almost finished result.
I'm going to add a couple more grommets on either side of the cage b-pillar for a couple more mini-bungees. I'm not sure how strong it would be driving down the freeway so I may only use it for around town and trail riding. Before anyone says anything, the cage is not done yet. It needs a lot more tubing which I still need to get. All-in-all, not bad for a $17 investment. There's enough material left over to make another in case this one gets trashed. I could have used heavier or waterproof fabric and heavier bungees but this will work to keep the sun off us. Total time was less than two hours.
Socal Tom
San Diego, CA
The mini Bungees probably won't hold if you go over 30. Get some good nylon straps for the corners. It looks good otherwise.
Tom
Hal9000
Flagstaff, AZ
Sewing a couple straps in near the center so you can tie-off to the roll cage would also help keep it from flapping at higher speeds.
gddyap
gddyap
Mtn View, CA
Tom
I wasn't worried about the bungees. I'm not sure the light canvas could survive at freeway speeds even with nylon straps. This will get us through our upcoming trip. I'll tell my wife to look for some heavy vinyl like the Kayline is made from the next time she goes to the fabric store.
bigmuddy
Marthasville Missouri
Good lowbuck idea! I wouldn't waste my time with vinyl from a fabric store. I would go hit a few upholstery shops and see if they have some quality vinyl they might have hanging around that they would sell cheap. If your going to take the time to sew it up and make it look nice, it might as well last a while too.
Ben
Hal9000
Flagstaff, AZ
The upholstery shop in Phx that I shop used to sell automotive grade vinyl for about $9 a yard. I'd guess you need about 3y to do a full size top (actually more like 2 yards and change, but they don't always sell fractions of yards). Sewing that stuff is near impossible with any kind of home sewing machine though (ask me how I know ;)). You might be better off just spending a few bucks and having somebody stitch it up for you using your canvas top as a template.
jdcone
riverside, ca
Yeah, that cheap vinyl won't last a month. You have to ask for boat material, SunBrella. I don't think that canvas will like the sun either. But she did do a nice job. You may want to add 4 ties @ the top of the rollbar too. These are all the things I had to add to the top my wife made for me. She even installed 1/8" rod from the windshield to the rollbar where the rollbar ties are. This helps stop the top from lifting @ freeway speeds.
matt w
Hey THAT is great! ;D
I love seeing home fabb'd products like this take shape! Great Job! ;D
Sweathog
Lansing
Good use of $17 and 2 hours. Many have done worse for one weekend of wheeling. Thanks for sharing.
