- Aug 11, 2004
- 1,893
koh
awesome write up...
awesome write up...
You'll be fine with 1350 ujoints as long as you can get enough angle. 1350's are what we ran in our 4400 car without any issues. they even survived twisting off a few pinions landing under power, shouldn't have that problem with a 60. I'm a fan of gearing the axles, the car will handle better, the added torque load to the chassis can make some funky handling, and the 33:1 will be far more capable than you think, and you are on the right track, anything past 50:1 is a waste of effort, (both of my rigs are 42:1) also remember your racing the crawling will be slow but not like out for a trail ride slow, less gearing will be your friend and be easier on your axles. Once you've done this a while you'll go on a trail ride and be wondering what is taking everyone so long...LOL
The only way I'd consider keeping the 4.10's is if you add a LOT more power and can keep the weight down. Weight kills performance so be mindful of every nut and bolt you add and strip out everything not required.
So I am getting ready to pull the body, but I've noticed most people do some kind of bracing in the door openings. I have never had a Bronco body off a chassis before, but I can see how it would be pretty flimsy without some kind of support.
Does anyone have any input whether the existing cage should be enough to support it, or if I should get busy welding up some bracing? It seems to me the cage should be sufficient, but I don't want to make that assumption and throw the body out of whack.
I would absolutely brace across the top of the door openings, also i would brace from the firewall to the core support if you intend to keep the front clip. a single round or square stock will work on the openings. I also braced across the tailgate area - but since you aren't running one then it may not make much of a difference but the tailgate opening tends to spread apart
That's sad when you want to move from pulling the body apart to grinding brackets off the axle haha I am sorry for you!
Are those stock chevy knuckles?
Good call on the grizzly, I have ran one for a year, I replaced an Eaton E locker with it just for simplicity when I went full width and I haven't regretted it. Grizzly front, spool rear is a solid combo.
I would be curious on fender weights as well. You can always just drill new holes to mount the fenders, or don't even use the original mounting points, make your own and use fiberglass body mounts like the ones AutoFab makes, Kartek has a bunch of mounting solutions.
I have not been around the KOH races much but I have been around/raced a lot of short course racing and tough truck racing. After reading through your posts I would like to offer some tips that I think may help. I am in no way trying to offend you with any of these tips just trying to help a future fellow racer out.
I think that you should make friends with some fellow racers to help crew for them first that way you will get a better idea of the work that you are up against. Then I think that you should focus on the safety aspects of this build first. Build a good chassis that will last {i.e. a good cage). Then follow Landshark99's suggestion of servicing everything and installing the explorer motor stuff. I wouldn't even worry about a cam right now. Do these things to get you racing as soon as possible. Too many guys start out builds that never get finished because they run out of steam or find other interests or their class gets cancelled before the build gets finished so that they have to start from the beginning again, ask me how I know. ( https://www.ford-trucks.com/forums/1587228-off-road-race-bronco-7.html).
Second you must force yourself to work on your race car. DO NOT stay out of the garage because it is cold/hot. Treat this project as a JOB until it is finished. Stay on one aspect of the project until it is finished, when you jump from one area of work to the next things get missed, bolts don't get tightened, fluid doesn't get added, or parts get ordered twice.
Next do not expect sponsorship from anyone, keep promoting yourself and the build but see any help that comes your way as a bonus. Accept the fact that you will spend far, far more money than any rational person would be able to justify. This is not only a job it is also an addiction.
Lastly, know that when this build is driving, that the job isn't even half finished. Then next comes the repairing, rebuilding, reworking, improving, prepping and racing in a vicious cycle. Also the people in your family will need to accept the fact that your life and possibly theirs is now based around racing. Vacations will be taken traveling to races, birthday parties will be scheduled on non race weekends or celebrated at the race, and holiday's will be hosted at your place so that you will have extra hands to help in the minutes before Thanksgiving dinner, besides you can see the fireworks through the garage door while you are under the race car anyway.
Once again not trying to make you change your mind, just giving you some pointers. I do want to see this build completed because it makes me feel better about my own sickness.(lol) All of the difficulties and sacrifices will be worth the amazing memories you will make with family and friends, that is the ultimate reward you get for being involved in racing.
Also I want to be the first to say. Hello, my name is Cofferjl, I'm an addict and welcome to the club.
