landshark99
- Oct 13, 2011
- 1,401
So I got the steel and fiberglass fenders weighed, and they came out to 14.3 and 10.3 pounds respectively. Now while it may appear that there is a 4 Lbs. difference, it wasn't exactly apples to apples since the steel fender still had the lower supports bolted on, the side-marker housing, bronco script logo, and a fiberglass flare riveted on versus the fiberglass fender which was bare. I am betting the actual weight difference is only a pound or two.
I appreciate the advice, and don't worry, I am under no illusions of grandeur! While I don't have any racing experience yet, I think I have done my homework and have a good idea of what to expect and understand the grind that goes along with building and campaigning a car. I do wish I had had been able to pit for a team prior to starting my effort (planned to last year, but things fell through).
King of the Hammers is a once a year race that is the first race of the Ultra4 series which consists of ~5 races throughout the year (KOH, ~3 regional races, & nationals). Many folks only commit to KOH, which is kind of the boat I am in. There are a few regional races I may try to make after the rig is done, but I have absolutely no interest in the short course races with man-made boulder fields on a dirt track. I figure 1 race a year for sure (KOH) plus maybe one or two others at my discretion. I am not going to be chasing the points championship for the series, or be traveling to go to a race every weekend. I might enter the rig in a local WE Rock event in the Sportsman class from time to time as well or do a NORRA race just for fun (I know it won't fit into any class rules).
How much $ are the fiberglass fenders vs steel? As you mentioned, the chances of body damage are very high at KOH so chances are you will be replacing one or both. Personally I wouldn't worry about the weight differences in the body panels, an early bronco actually doesn't have much weight without the wagon top above the belt line. I would be more concerned with the COG with the cage, tires, coolers and all the other crap you have to add. Personally i I think you made the right call on the 2" cage (I did the same). I would look at using smaller diameter tubing for areas outside the passenger compartment off the main compartment - but you already know this I am sure.
I would cut and reverse both driver and passenger floors so that the seats sit lower, this will open up a ton of seat options. Allow better visibility out of the front and allows you to build your cage lower which will help your COG. There is a floor channel under the seats that supports the floor you will have to cut out and fab a replacement, however you will run tubing between the cage across the floor anyway to mount the seats to and that should solve the floor issue.
I had to replace a TON of sheet metal on my build. It was important to me in my build to keep it close to stock and have a very nice even platform to build on and I bought or traded for replacement panels instead of fabbing my own to save time. I did all the sheet metal replacement and repair myself and had to keep reminding myself this was not a restoration. When I found myself trying to get things perfect and mired down, I had to stop and do a self check and tell myself this thing was a race bronco and it was going to get messed up.. make it reliable and get it done.
As far as getting it done and racing - I got allot of advice before, during and after my Race build... mainly because advice is free - most of the time
Find a partner(s) in crime to help with the build and race(s). It's a tough go to build something that will last any race and even tougher to go at it alone. Find someone who has the passion and drive to help you build it and race it. I know location might be a factor but they don't have to be there everyday or even every week - just having someone sourcing stuff or cleaning things up so you don't have to saves you hundreds of hours. Maybe you find someone tomorrow, maybe in a few months -
I would also think about farming certain aspects of the build out to others (if you haven't already), it might cost you a little more but it will save you a ton of time and your sanity. I had my engine, transmission, transfer case and cage built by others. I just made sure the others could and would do the work
We plan on racing NORRA this April/May. I know of at least 4 other Early Broncos that will as well. I don't have all the logistics figured out quite yet and I know its not a KOH race but you should think about coming down to check it out. I currently don't have any plans to race any state side races this year unless NORRA gets pushed back again but will keep you in the loop if we do as they would be a much easier attendance.
As far as racing NORRA for your rig - there is always a class and you would not be the only Bronco in it. Guaranteed.
Keep pushing and more importantly - figure out a heater!!!
