Shaving a Sterling?
av8rds
MAhole!
2300 mi East of Moab
I'm not home now so I cant look at mine to check....but is it possible to shave a Sterling 10.25/10.50 like you would a Dana 60 or 14 Bolt?
didnt see anything using search.....
I know a 14 bolt has a ton of room between the ring gear and the ground. I thought the Sterling already had the ring gear pretty close to the case, which would make shaving it nearly fruitless.
00gyrhed
I dont know for sure because its been over 10 years since I had mine open, but I think theres less than an inch to be gained.
bknbronco
North Metro, MN
I have never seen a stearling but i say if you can gain a 1/2" to a 1" then its worth it. Im gona shave my 9" and my 44 this winter. For every inch you gain it like having a tire that 2" bigger!!!
broncnaz
From what I've heard a stock sterling has the same clearance that a shaved 14 bolt has. Not sure if the sterling has much room to shave any off it or not your going to have to pull the cover and determine for yourself. But in this case I think it will be more work than its worth.
SpareParts
From what I remember when I did my ton swap.... The Sterling in stock form compared to a 9" in stock form with the same tire would have only lost 1/4". The 14 bolt on the other hand was horrible, hence the reason I shaved it. I do think there is a bunch to gain if you take the webbing off of the Sterling. The width of the pumpkin is quite a bit wider than the 9" or the 14 bolt. My reasoning behind going with the 14 bolt instead of the Sterling was the pinion length, Sterling was 13 1/2" from the axle centerline, the 14 bolt was 10 1/2" and the 9" was 9 1/2". With that I used the offset spring perches from RuffStuff and moved my rear back 1". This allowed me to use my existing driveshaft with the exeption of a new 1350 slip yoke. I had 2 Sterlings sitting here, and had to buy the 14 bolt, but with the doubler I had no extra room for a longer pinion.
DanWheeler
Kirkland, WA
I dont think it's worth your time and oil mess from the inevitable leaks. I did the comparison to my old 9" and it was negligible.
here's a thread on pirate. Seems like a waste of time to me.
http://www.pirate4x4.com/forum/ford/790669-sterling-shave.html
Sterling with 41s
