Finally had some time to install the new 351w and Top Loader 4-speed.
Ended up being pretty straight forward and hardly any special parts or modifications needed at all. Used the same engine harness (new replacement) as the stock 302 and some extra wiring for the distributor, but no additional "stuff" at all. Still looks fairly stock and clean. Even installed a manual choke carb as stock was. (my preference anyway)
The shifter that came with the 4-speed conversion kit was way too long and actually hit the steering wheel, so reverse was impossible to engage. Replaced this with shorter Hurst shifter. NO other modifications were needed for the transmission install because the 4-speed is within 1/2" length of the stock 3-speed. Transfer case mount is in the same location and stock driveshafts still same length.
Also replaced stock steering column with a direct fit Ididit Tilt Column with no shifter, can install Ford steering wheel and was able to use the factory electrical plugs, so this was straight forward as well and looks stock as possible.
Still have a few things to adjust or button up, but it's about 95% done now.
Here is what it looks like from the engine bay:
