Shift rod 74 auto column
ps6123
Denton
Does anyone have a couple of photos on how the shift rod attaches to the column and C4 transmission.
Have column and transmission but do not have the rod, connections or information how to attach the two
Viperwolf1
electron whisperer
The top of the rod snaps into the plastic bushing in the column lever from the front. Don't put the bushing on the rod first then try to push it through the lever. If you need a bushing you can get them at o'reillys in the help section. Bushings are only good for one installation and typically get destroyed if you have to take it apart. Bottom of rod fits into the slotted swivel bolt at the trans lever. Below is adjustment procedure.
Block the wheels and set the parking brake. Loosen the linkage nut on the trans lever so the linkage rod can move freely. Move the trans lever to the neutral position. That's 2 clicks down from the park position. Make sure the column is set to the neutral position. You might need to have someone hold it there. Now tighten the linkage nut. You may need to readjust the neutral safety switch (NSS) after this.
Loosen the 2 small bolts holding the NSS. Block wheels and place trans in neutral. Insert small pin (1/16" drill bit) in hole in side of NSS. Adjust NSS body back and forth until pin can be pushed into hole approximately 1/2". Tighten NSS bolts.
