Shifter tunnel Carpet question.
71massbronco
How do you handle the gaping hole on the hurst 3 speed conversion shifter?
I have a new ACC carpet and it has some jute backing, but won't that just get saturated with dirt and road grime from underneath as time goes on? Is there some kind of boot or rubber I should affix from under neath to prevent water and other nasties from making their way into the shifter opening? What have you guys done?
airbur
Castle Pines, CO
Having this cut out of .25" aluminum locally this week to cover mine up.
broncoitis
1/4" ????? :eek: Holy Crap! Don't ya think that might be a bit much? Just askin. LOL! Definitely will be SOLID!!!
DuctTape
Bozeman, MT
Another alternative i saw someone do is to just tuck the carpet under the edges of the hurst shifter cover.
71massbronco
71massbronco
I didn't make it clear, I have the shifter there that I need to carpet around. I plan on putting the carpet around it, but think there should be something under the carpet next to the shifter to keep out the elements.
DuctTape
Bozeman, MT
You have a hurst floor shifter, yes? Are you using a pre-cut carpet set?
My pre-cut carpet was cut assuming there was no floor shifter, but either way if I understand your question right wouldn't you a) trim carpet to fit under edges of shifter boot or shifter cover (yes, the edges might wick stuff up); b) sew some rubber trim onto the edges and fit that under boot or shifter cover?
By cover I mean the custom panel that needs to be added to accommodate how the shifter protrudes into the driver floor pan area.
Thinking more about it, if you are concerned about wicking (I'm not but ymmv), if you could find some sort of u-channel rubber you could wrap the edges in that.
Crush
Greenbottom, WV
All factory standard shift trucks and cars have two boots. One screwed to the floor before carpet and has a seal to the sheet metal(called inner boot I think). Then carpet goes on. Then the decorative boot goes on. Find one of the inner boots at the bone yard and use it
.94 OR
Willamette Valley, OR
I'm not sure the pick-a-part approach will work real well for the 3 speed on the floor. I had concerns about this when I bought mine years ago and sure enough you get muddy junk splashed up there. I had always thought I could use a piece of rubber mud flap or inner tube to create a splash guard or something that would deflect the spray but I wasn't sure how to get it good and tight to the bottom of the floor.
tasker
all knowing of nothing
NH
what about a shift boot on the bottom? turned upside down.....something small like from a subaru or something?
71massbronco
71massbronco
^^this!^^
I think I know what I'm going to do now. thanks guys.
