Winters Shifter and Tunnel Modification
RustBeltRefugee
Santa Clarita
I pulled up the carpet and found a lot of surprises. The floors were pretty solid in that there was not too much rust but there were a lot of scars from previous modifications. There was a cut out for an old shifter that was no longer being used. There was a cut out for an old hand brake? And numerous holes from who knows what. These holes were partially covered by a warped plate of hot rolled steel and tack welded down in a couple of spots.
R
RustBeltRefugee
Santa Clarita
This is how the winters shifter was mounted. The truck came with a C6 trans and no body lift. Adding a body lift was not an option since the truck barely fits in the garage as it is so I decided to cut out the floor and add a tunnel.
Hopstr
Nice work on that. Can't wait to see how it turns out.
R
RustBeltRefugee
Santa Clarita
Thanks Hopstr. This is pretty much my first mig welding project. It has given me a lot of seat time without using a whole lot of material. I ground down the ugliest welds and eventually my welds started to get presentable. I started this project about 9 months ago and I am just now getting to the point where I think it might actually work. I will post some more pictures soon. This is what I used for a welding table. It is an old mounting plate for an ATV snow plow clamped to a saw horse. ;D
R
RustBeltRefugee
Santa Clarita
Thanks 66Horse and broncoman1972. Please bear with me as I try to put all of this together. I am having trouble attaching multiple pictures to a post.
I built the rear section first then temporarily clamped it in place. Then I cut out cardboard templates to get the shape of the sheet metal that will go between the rear section of the tunnel and the firewall.
R
RustBeltRefugee
Santa Clarita
Had some extra space toward the back so I added a storage box and lid. Bought bronze bushings and stainless steel pins threaded on one end from McMaster Carr. Used 5/8" diameter x 1/8" wall DOM tube for the hinge point. I drilled holes and aligned the tubing with a long 3/8" bolt. Lid works pretty good and is tight enough that it does not rattle.
R
RustBeltRefugee
Santa Clarita
Finished welding the transmission cover and ground down the welds. Had a lot of shrinkage along the weld seems and the top of the transmission cover oil canned a bit. I think I welded it a little too hot. I was able to get the oil canning problem fixed by putting a cross peen body hammer along the inside corners and hitting that with a brass hammer. That was a workout.
Welded the tunnel cover frame to the floor then cut out the floor support brace that was in the way of the transfer case. Ended up cutting out the parking brake equalizer so I will have to figure out a way to get that back in there and working again after I get all of the other parking brake parts that have been missing for years.
Made cardboard templates for the tunnel cover.
