Shocks or full suspension replacement?
Dover
Finally got my dream Bronco (1966). The body work is all complete and it has a 351W swapped in. I do not know any of the history of the drivetrain and I assume at some point that will be my project.
That said it has a 3-3.5" lift on it (will measure later) and it's running 33's. The shocks look like they're 15-20 years old so I figure at the very least will replace them, but then I figured I would ask if it would be worth jreplacing all the leaf springs and coils as well? As far as I can tell nothing is 'wrong' with the suspension, it's just old. I assume a replacing the leafs/coils buys me nothing but figured I would ask the experts.Thanks
SLOWnEASY
San Diego, Ca.
Personally I would leave it as it is unless it's cupping the tires or you don't like the way it drives in some way shape or form.
As others stated, drive it first. You need a baseline at some point.
A stiff ride could be shocks, or springs, or both. A test drive with no shocks should be very floaty ride, but if still stiff, it is the springs. Changing shocks won't fix stiff springs.
15-20 years ago was when the new era of soft springs was going mainstream in the Bronco world. You might already have good stuff in there.
SteveL
Huge chevy guy
Hawthorne ca
How many rear leafs are there? 5 or 6 it's probably the old stuff springs and worth upgrading . If it has 9-11 rear leafs you have the newer style springs and might just need to upgrade the shocks. But now more vendors are offering 4-ling set ups for the best of both worlds
Brush Hog
NorCal
Drive it. Enjoy it. Then work on what you don’t like (ride,handling, stopping, stance, etc). Early broncos are a disease/life style/hobby. Make it yours but make sure to use it. Research is key.
Dover
Dover
Appreciate the perspective fellas. I've driven 100 miles max on her so far. Other than her driving like she is 60 year old vehicle it seems fine. Just itching to improve.
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
Chances that a simple shock change would make a significant difference is very small. If the shocks aren't seized and the Bronco isn't pogo-ing over bumps, new shocks aren't going to change it much.
Bruners4
1/2 way to everywhere
My project has an older 3.5" WH lift kit with shocks that sat unused for over 14 years. I've put over 4k miles on it now and it rides very smooth. It has the 11 leaf rear spring packs on it. Shocks had the boots installed and they are not leaking at all. Very happy with it.
I agree that unless it is jolting you out of the seat or shaking the bolts out of the frame to drive it. Also lowering the tire pressure to below 30 PSI will help with the ride and tire wear.
serial car restorer
Western Oregon
So... full disclosure. I did replace the shocks on my '69 long before driving it. But in my case, it was not just that they were old, they were also not a matched set of 4. The rears were ancient Monroe spring assist coil-overs (that actually lifted the rear an extra inch), fronts were very old Rancho RS5000. I'm not expecting much difference in ride once I get it on the road, as my springs are old-school—3" lift front and back from 6 leaves (5 + breaker) and non-progressive coils. So I know it will be stiff. But less stiff without the extra rear load-assist shocks in back.
