Did any of you guys go from an NP435 to the NV3550?
The only one I could find is made by B&M . I bought mine from Summit but I think TBPs has em . Hurst and B&M used to offer 2 different shifter "rods "/configurations / bends but Hurst totally discontinued theirs and B&M only offers the one style now.
Like others I found mine to be too close to the dash for my liking . I called B&M and talked to a tech and he said " just bend it " so I wrapped the shift rod in heavy cardboard {I think - don't exactly remember what I used} put it in a sturdy vice , slipped a piece of pipe over the tapered end and bent it . Basically I increased the amount of factory bend . I wasn't going try to bend the "rod " at a different spot as I was already leery of bending it . I didn't bend it far enough the first time but got it closer on the second try . If I ever remove the shifter from tranny again I'm going to bend it a little more.
The biggest difference between the OEM NV3550 shifter and the aftermarket B&M is below the shifter's tower.
You can shorten the lever all you want and still won't have a short throw shifter.
It's the lever below the tower that makes the difference.
