Shortening Duff Torque Tamer
BruiserOutdoors
I will likely have to shorten my Duff TorqueTamer by about 2".
I am running the SPEED GEMS SBF to 6r80 adapter which shifts the transmission and transfer case back 2".
Any thoughts/concerns with doing this? Is there a better location on the torque tamer to remove 2" ? My plan was to take 2" out of the straight section towards the front of the bar.
Thanks in advance for your input!
Yeller
Rogers County Oklahoma
It will increase lift in the rear when accelerating hard, I would only shorten it if absolutely necessary, the negative effects will be minimal but noticeable
bax
Old Member
Any thoughts on moving the rear end back an inch? That will help some. Also the Duff tamer is pretty long. Much longer than the WH tamer. The WH one works good. I dont see where taking 2'' of the duff one would hurt much.
BruiserOutdoors
BruiserOutdoors
Never seen the WH one, couldn't find it on their website. Link ?
Good tip on moving the axle back, I will have to consider this.
Not at my computer at the moment but try searching wrap trap in our search box. See what comes up.
I’m not aware of it being discontinued, so if it’s not showing up on the website at the moment it’s probably because we are expecting a long wait for more to come in.
But it might be there, so try that search I mentioned.
bax
Old Member
Here it is. Wrap Trap. I have this on my 71 and the duff one on my 68. They both work.
bax
Old Member
Here is the wrap trap on my 71. It is much shorter than the Duff Tamer. I am sure you could cut down the Duff one without any ill effects.
Keep in mind that you can't really compare the wrap trap to the torque tamer.
The torque tamer is a true torque arm. The torque is captured in the arm and transfered to a vertical thrust, body up, axle down. The leaf springs are transferring zero torque from the axle housing. I had a pre-Duff version made from a radius arm. You got a good vertical lift when you got on the throttle. Never had any wrap/hop even with sagged out 10-leaf springs and lift blocks (about the worst case possible)
The wrap trap is a limiting pull bar. As the axle tries to rotate (axle wrap) the upper link is put in a state of tension and the leaf springs are put under a state of compression. The leaf springs are a flexy link in the torque managment. How much arc do they have? Are there lift blocks installed? How soft or firm are they?
Torque arms are will proven across many platforms. From off-road to road racing. OEMs have used them for a long time as well. The idea goes all the way back to torque tube axles and those are still used in sprint cars.
JWMcCrary
I shortened it 4 inches on both my broncos due the doubler adding length. Never had a problem and to this day never lost a ujoint in th3 rear, One of them has a 393 with 400+ HP and no issues.
BruiserOutdoors
BruiserOutdoors
please post some photos of it if possible. I am curious where you took the 4" out and what was used to re-enforce it.
Should I cut, sleeve it inside the tubing and plug weld it? or just butt weld 2 beveled edges?
JWMcCrary
Well, I guess I'm not smart enough to post pics since the site upgrade. It was very simple, the end that goes to the crossmember, cut the bushing mount off, shortened the length 4 inches, and then welded the bushing mount back on. There is a thread on here that I started when I added the doubler and I did the first one, it's going to be close to 10 years old, it would have pictures I'm sure.
MonsterBIlly
BroncoBowsher
Your post is interesting. I have the wrap trap and have noticed that since the install, when i accelerate hard the rear squats hard to the ground. it really sags. It has helped with traction but it really sags a lot on hard throttle. not what i was expecting.
I have not heard others mention this condition, but it's possible that some of the energy previously used to twist the springs into an "S" shape is now compressing the springs instead? Seems possible.
What's the rest of the setup besides the 37" tires? And were you using the same size tires and gears before the Wrap Trap install?
I just remember making a torque arm out of a radius arm (same concept as the Duff arm, I used a tractor heim and a leaf spring shackle hanger instead) and I didn't have squat issues. Torque the drivetrain and I got a good rise. It hooked hard, never hopped, never lost a U-joint.
