Post some pictures of the dual 3" setup!You’ll find 2–1/2 pre Y pipe or pre muffler is more than enough and 100x easier to fit. I’ve built a lot of exhaust, 3” is a bear compared to 2-1/2 and the engine requirements are well met, unless your exceeding 6500rpm.
Would if I had some….. sorry.Post some pictures of the dual 3" setup!
They look killer. You're going to make me build a set of fenderwell headers too!I'll post pictures once I get it finished, still waiting on parts so it may be a bit. Running 1.75" headers and planning on 3" outside the frame tucked up above my slider supports, undecided on mufflers.
Here is a picture of the headers, a friend built them for me as I couldn't find any shelf options for my heads.
Sounds pretty cool. How did you get 3" around the Dana 20 on the driver's side?Would if I had some….. sorry.
Everything I’ve ever done 3” duals was a 500+ CI big block. Even the 400ish CI Ultra 4 cars have had 2-1/2”, but they redlined at 6200ish. 2-1/2 was what our engine builder/tuner/dyno guy wanted, we were only pushing 570ish at the crank, but it would do it all day running 5000-5500 and be happy.
There are lots of options when building an exhaust system. A common option is a transition from round to oval in tight spaces. Other than the one tight spot between the frame and the transfercase on the driver's side, there's a lot of room to route dual exhaust.Well, there you go! The answer to lack of real estate in a bronco was always answered by fender-well exit!![]()
Congratulations on your very impressive dyno! You must be so proud.I just dyno'd over 600 hp and 660tq.
Outlaw1, what are your numbers? Why do you need dual 3"?
Definitely curious. Could you answer these questions?
1st is rpm, what is redline?
2nd is head size
3rd is what size hp nitrous shot
4th is have you run it yet? That D20 doesn't stand a chance if you actually put some shock & load to it. Just won't.
5th is how is your 4r built
6th is check out how many cars running sub 9 sec qtr mile ET's have 2.5" exhaust with mufflers. Answer is: a lot.
Everything Yeller said also
Not a bronco…. You can fit whatever you need in a custom tube chassis.Sounds pretty cool. How did you get 3" around the Dana 20 on the driver's side?
Oh boy, welcome to the site...There are lots of options when building an exhaust system. A common option is a transition from round to oval in tight spaces. Other than the one tight spot between the frame and the transfercase on the driver's side, there's a lot of room to route dual exhaust.
Well, I want to run 3" exhaust and I asked who else had run 3" exhaust. If you haven't done it, I'm ok with that. Why would you feel the need to question me?
#1 - "Redline" is a term old people use to describe the maximum rpm you plan to spin your engine. It makes it sound important.
#2 - Yes, or big, whichever you prefer.
#3 - Depends on what jetting you choose.
#4 - I drive it every weekend I'm home and on long trips whenever possible.
#5 - It's a stage eleventeen build.
#6 - I guess that's why my race car has 5".
I'm happy you and the other guy agree on things that don't pertain to my thread.
This is going to be fun to watch![]()
