So the good news is while I'm not rich by any means, I'm thankful to finally have some time and money to throw into my Bronco.
So I'm starting to make it road worthy again and a little nicer. One of the thing that bugged me was the mirror mounting. They always were kind of loose.
A little research indicated that this bagged Scott Drake setup is the right screw / insert setup for my model.
Removing one mirror, I see the mounting holes had a metal insert that's a smaller diameter.
Obviously I could drill out the metal nsert, enlarge the hole for those Scott Drake inserts... But first wanted to ask if there was a better solution, or if anybody has successfully used these.
Thanks for your help!
