Silicone Intake Hose Planning Help
airbur
Castle Pines, CO
I'm to the point where I need to connect the TB to the MAF and filter. I have never built one of these before....so am attempting to learn what I can.
My setup is an Accufab 80MM throttle body to a Pro-M 80MM MAF calibrated for 42lb injectors. Pro-M says their housing accepts 3.5" hose, and the Accufab throttle body is 5" in diameter. I've read that it's best to try and go wide at the MAF and smaller until you get to the TB. With this setup, I don't see how that's possible.
Is it best for me to start at the TB with a 5" bending reducer down to say 4", then aluminum pipe and another reducer down to 3.5"?
Thanks.
