Single stage air compressors
Crawdad
I'm picking up my dual stage 80 gal 5.0 hp IR from Tractor Supply today. I had it on layaway for two months. Got it on Black Friday for $1k plus 4yr warrantee. They load it on truck, I gotta figure out how to get it off! Hmmmmmmm?!!!!
allenfahey
Question is what do you plan on doing with your air compressor? A single stage will not have enough CFM's to run a paint gun, DA's, or even grinders if used for long periods. A dual stage compressor is a much better choice. Right now you might not plan on paint/body work but if you ever do you will regret the single stage compressor. Save up or look around on Craigslist for a used one. I would try find one with a minimum 60 gallons and 5 horse minimum and that still won't run a spray gun like it should. 80 gallons is better.
Dbarnes72
Dbarnes72
Eastern Wa.
I do plan on painting (one project). My target is $1000. This compressor lists comparable or better CFM's than the equivalent 2 stage but I am here for advice....
Apogee
I would sooner buy a used 2-stage compressor operating at a lower RPM than I would a single stage operating at the ragged edge. Your long term costs of the two-stage unit should drop significantly for comparable cfm/HP units, or your performance should increase substantially for larger units. I'm looking at 80+ gallon, 7.5 HP or higher compressors for all around utility and value...you can find used units on CL occasionally.
cracker
Pueblo, Colorado
Tailgate down and use the skinny pedal! Should unload it self pretty easily....;D
allenfahey
The CFM ratings are a bit far fetched on air compressors IMO. If you use the HVLP fittings like you are supposed to when you paint you will use a ton of air. HVLP stands for High Volume Low Pressure. When you use a spray gun and paint a vehicle all over you need a constant 10-15 minutes of air non stop. You can't wait around for the compressor to catch up. You have to be able to keep a wet edge when spraying sealer, single stage, and the clear coat. You will also use alot of air when you use a DA. Single stage compressors are OK to remove lug nuts with an impact but not for body/paint work.
bk005
San Antonio
Ive bought a $2500 80 gallon 2 stage Gardner Denver before, and spent more money and had more CFM than my needs and its a beotch to move. Now I have 60 gallon single stage, and 30 gallon back up incase I need a bit more when spraying or doing minor blasting.
I agree buy the best you can afford, but dont go to the poor house doing it. If you painting a car once every couple of years, hard to justify IMHO. Necessity is the mother of all invention.
