I'm rebuilding a used motor 5.0L outta a 92 Mustang and in the mist of installing the new timing chain set, I noticed about 1/4" slack in the new set. I've done some research and consensus is that the block was aligned bored at one point, thus causing the slack. Does this make sense? If so, can I order a small chain or larger camshaft gear to take up the slack?
