Great to hear! Glad that helped. It almost always does, as long as you don't have to fight the alignment guy who "always knows better" and then re-sets it the wrong way!
So don't let them change it back when they're setting the toe-in (in case they even need to change it that is) and reinforce to them that this new angle you have it at is in fact the same as the factory original angle.
Although it certainly made some change in the toe-in, it was not much and may even have improved it. Since what toe-in setting works best with any given Bronco is kind of dependent on the individual Bronco's setup and the driver's personal preference, it does seem to fall into the same window that the factory recommends. Which is I think 1/8" to 1/4" or thereabouts. I seem to remember mine always liking it about in the middle at 3/16 inch. But I could definitely feel the difference when it was changed.
Be great if when you have it checked, and if they need to change it a little bit, that it feels even better!
And then don't forget to experiment with tire pressures over time. You're looking for even tire wear (especially in the rear where they sit more squarely on the ground), driving feel and comfort. And the nice thing about air pressure is that it's easy to change, then easy to bring back if it was better before.
Good luck.
