Small victory, floors about done
bobscott
Just a bit more fitting and screwing and I will be ready to weld. Replaced everything except the wheel wells and the little filler pieces in front and behind wheel wells.
Figured out why the driver side door didn't want to close right. It appears the Bronco saw a bit of air time in it's past. The support under the driver seat was completely disconnected from the body and the support under the front pans was a bit bent where it bolts to the frame. Also the front support had seperated the inner rock and bent it up on the driver side. Had to cut the front support out anyways to fix a bit of rust on the kick panel/rocker/door post. Doors line up and close now probably better than when it was new. Some new or rebuilt hinges and I will be in business.
Also found a media blaster this weekend, hope to get the body off the frame and to him this weekend.
Before
After
The distraction keeping me from getting more done.
The little one doesn't quite understand what kind of Bronco's I want to spend time with ;D
bobscott
bobscott
Didn't replace the cross supports just cleaned them up and KBSed the inner channel and put a coat of weld through on them. Had to massage the front support with a 2lb hammer though to get it straight again. The funny thing was as nasty as the floor was the cross support still had a factory stamp on the inside. They cleaned up perfectly except for where the captured nut was for the passenger seat. I just cut out where the nut was. I figure I will come up with something else to mount the seats than the captured nut. I plan on putting the seats back a bit from stock location anyhow.
Rustytruck
Wont be long before she gives up that 4 legged Bronco for a 4 wheeled one. Best pick up the pace on that rebuild.
