Smog test--failed miserably
bmc69
This site rules! What would i do without you guys? Can anyone tell me where the fuel filter is? I think im just going to have to install an in-line filter right where it goes into the carb. I hope my mechanic will be able to spot the choke housing missing. Where could i find these missing parts?
If the only thing missing off the carb is the actual spring housing itself..you can buy those new at any autoparts house. If the clamps for the housing are missing..time for a junkyard trip. The vacuum pulloff must be checked for a blown diaphragm..and it too is a standad autpoarts part. You will need to make sure also that your heat source tube from the exhaust manifold to the choke is functional (or if it is not or is missing, that can also be had as a kit in the 'Help' section of any autopart store.)
rsharpnm
Las Cruces
The heat tube in your photos is broken in the exhaust manifold. Not too hard to dig the broken nib out of the cast, but you'll need a new tube. Scavenge one from the boneyard or order a new one. The clean, hot air is VITAL to the choke working correctly.
Or go manual choke.
Also want to add... I don't use timing lights on older engines any more. Use a vacuum gage and adjust to the highest manifold vacuum. Timing and mixture screws both. Timing rings slip, chains stretch, etc. A vacuum reading is always constant.
Real Big Stache
Real Big Stache
Henderson, NV
Regaurding the choke, If the thermostat housing is missing and other componets that make it an electrical choke, it is possible that someone abandoned all of this to convert to manual choke right? I do pull out a lever on the left everytime i start her up.
Mechanic called and agrees with all of you that the carb is FUBAR. Getting a price to replace it. Another question, should i upgrade to a four barrel carb or stick w two?
Right off the bat, you'll need to check with the smog guys (or the state's website perhaps?) to see if that's even allowed. Sometimes it is, sometimes not. So before you spend money, make sure it's allowable.
Unless Nevada does it different than everybody else, you should not have to ADD anything that the truck didn't come with from the factory. You might definitely have to re-install things that were removed, but to update it to later smog stuff? Nope.
The fuel filter is indeed that thing you pulled out of the front of the carb. If the one you bought didn't fit, either it was the wrong one, or the carb on your truck is not the original.
With Broncos it's probably a one-or-the-other-or-both kind of thing.
Your air cleaner should be ok, as long as it's still sealed and only breathes through the snorkle with the heat stove. That's the large tin/cardboard like tube in the one pic. It just slips over the large round tin-like shield on your exhaust manifold that you can clearly see in the same pic.
The '71 model year did have the heat riser, but only came with a simple spring-loaded heat-sensitive flapper valve in the snorkle. Since that's a different air cleaner than stock for a Bronco, you should still be ok because of the vacuum pull-off type of shutter/flapper it's probably got inside.
Basically, they just want to see that it's breathing in the pre-heated air off the exhaust when it's cold, then as the engine warms up, it opens up to allow cooler air in.
Same for the rubber tube coming from the bottom of the air-horn area. Simply slip it over the metal tube adjacent to it.
Get a new choke coil (thermostat) or the correct linkage so they won't question what it came with. Even though Broncos were available with manual chokes up to about '69 or so, you're not supposed to convert automatic to manual.
However, since some years did have manual chokes, you could probably make the carb look more like a manual choke carb with a linkage change, but it probably all depends on how savvy the inspectors are too.
Either way though, make sure that the choke is not leaking vacuum through to the carb like was mentioned. That's not likely to help the cause.
Good luck.
garberz
Bronco Influencer
Conejo Valley, Ca.
You'll have to stick with a 2bbl, when getting it smogged. Those 2100 Motorcraft carbs work very well when working properly.
Ranchtruck
You don't need a new carb. You need to fix what you have there. With basic hand tools and a little bit of patience, you can rebuild that carb with a cheap kit and have it up and running fine. Your main problem is the choke. A closed choke will make you fail any emmisions test You could probably fix the choke with a new heat pipe, choke coil and cover and a little bit of adjustment, go back and pass the emissions test. Post up what the test results were for your fail. I bet the HC's were through the roof.
