Smoking engine - short term fix?
JohnJohn
Richmond
So I am taking my trail rig to the MEB Round Up tomorrow. I had plans to change out the engine but ran out of time.
The engine starts up fast every time but she smokes and is in need of a rebuild or replacement.
Any temporary fix ideas so I don't smoke up the trails?
I was thinking of dumping some Engine Restore in. I tried some of the No Smoke thick stuff but it did not help.
broncnaz
There's not much you can do. Fresh heavier weight oil may reduce the smoke but it wont eleminate it. Additives at this point are a waste. If the no smoke didnt make a differance then nothing else will.
72_EB
66to77
You'll regret putting that "no smoke" junk in if you ever rebuild it yourself. Makes a mess inside a motor. Have you pulled the covers to check you valve seals? Might be pushing it to do them in day if you haven't done them, but not a super hard job. You could do a thicker oil, if in a time crunch, but may not help a whole lot.
JohnJohn
JohnJohn
Richmond
thanks guys for the info.
I know I need to rebuild the heads or just change engines out I was looking to see if there was something new out there.
I will run at the back of the pack and see how she does.
TwoDalesDad
Add some Blenzoil to it...so at least it will smell good....like your at the speedway races
I'm not sure why you guys think that the oil additives will make a mess of an engine's innards. Maybe the "No Smoke" stuff is different, but I've used additives (thick and thin ones and many different brands in many different engines) and never found any residue of any kind inside that could even remotely be related to the additives alone.
That said, unless the No Smoke stuff says that it's going to react immediately, most additives take some time to do their job on an old engine.
I guess the thicker ones are designed to thicken the oil to the point that it's harder to pass the rings? If so, I guess that might be expected to act quickly. But I don't expect them to work for maybe one or two changes in some cases.
I know I've told the story before, but my original '71 302 with only 60+ thousand or so miles, smoked like a pig, ran rough, had less than the expected amount of power, and used oil to the tune of a quart every few hundred miles in my daily drive. Leaked some of it too, but used more.
A few go-rounds with cleaners and ring-free'ers and such, and within about 3k to 6k miles (a couple of oil changes) stopped smoking completely, stopped using oil almost completely, ran much better, and even had a tad more power overall. Gas mileage didn't change much, but it didn't go down at least!
Anyway, ran it that way from that point to the 175k mark, when I sold it to another guy who ran it as-is in a project car while he rebuilt the original in his. At that point mine was getting about 3000 to 4000 miles per quart of oil.
So maybe the additives don't always work, but they can. And while some may work right away, most take some time to do their job.
I've been happy with the results I've always gotten.
Sorry you're going to smoke up the trails a bit, but maybe it'll get a little better anyway.
JohnJohn
JohnJohn
Richmond
Thanks guys
I am going to run a compression test tonight and replace the valve seals. I also picked up some Engine Resrore. Like Paul said I have read that it a can take time to work. My trail rig is not fun to drive on the road so I may let it run in the driveway for a while.
I will let you know how it goes.
I have thought about just wheeling the 77Ranger but I stress to much pushing it through the woods. :)
needabronco
Prescott/Farmington
I personally wouldn't waste any time with the 'oil fix' additives. Dump in a couple quarts of cheap ATF (most of that stuff is basically ATF anyway) and let it run for a few hours, block the radiator a little so it can get nice and hot. Then change the oil and filter.
I just revived an original 66' 170 that would run but had no power and smoked. After 2 hours of run time it runs great and no more smoke. Granted it had sticking rings and valves, not leaking valve stem seals... If your valve stem seals are leaking they can be changed in a couple of hours in your garage.
JohnJohn
JohnJohn
Richmond
I picked up a set of Fel-pro valve seals and the valve spring compressor tool this morning and will try to replace them tonight.
I also have a compression gauge and noticed I can pull the shrader valve out and use the compression hose and connect it to my air compressor to hold the valves up.
I was thinking about turning my compressor down to 60 PSI to keep the valves up but without having too much pressure. Any recommendations?
I am also planning on rotating the crank until the piston is at TDC on each cylinder before I remove the springs just in case.
needabronco
Prescott/Farmington
There is an old school trick using a section of rope in the cylinder and then turning that cylinder to TDC, the rope will compress and hold the valves from opening. You might try to google that and see what comes up.
JohnJohn
JohnJohn
Richmond
One last question.
My trail rig is made up of many years. It sounds like I should have non adjustable rockers.
I have read that I just torque them down to 18 foot pounds and go but do I start with cylinder #1 at TDC then torq the two rockers on that cylinder then turn the crank 90 degrees and go for the next cylinder in the firing order?
Or can I just torque them all down without rotating the crank?
bk005
San Antonio
One last question.
I have never changed valve seals with a piston aired up, just springs. Id roll it to TDC and stuff some rope in the cylinder. Also if you do the air, dont leave your breaker bar on the crank, if your not exactly TDC, you will stroke that piston fast at 60-90 psi and your breaker will be a wielding instruments of death and destruction.
i start with all snugged up and at #1 TDC compression stroke. I cant remeber the cylinder numbers but if you google it you can find the ones to adjust, and you can do it all in 3 turns of the crank. I have it written on a card in my tool box somewhere when i need to adjust solid rocker pedestal like that.
If its still smoking as bad after start up Im afraid you might be wasting your time with the valve seals.
Do it like bk suggests.
You probably "could" do them all at once, but there are probably issues that could arise. Maybe not every time, but if even one proves trouble, you'd be cussing up a storm later.
It kind of makes sense, as it's probably a safety measure in case a lifter is pumped up all the way with oil and you're trying to tighten it down at the peak of it's lobe.
That might put extra stress on the stud and try to pull it out of the head. Which is an unfortunately common thing on older engines, or high-performance builds.
It's probably worth the added hassle of turning the engine over and torquing the nuts in their sequence. It's just a little more time after all. With all the energy spent to get things to that point, why take the chance. Right?
While it's not hurting anything to do the seals (except take some of your time), a constant smoking is more like rings than valve stem seals.
Still, if they're bad enough (or missing!), they can still cause some smoke. So carry on.
But another thing to look at is your timing. It's not common, but I've literally created smoke out of the exhaust on an older engine simply by having way to much, or way to little ignition timing.
To this day I'm really not sure exactly what was going on, as the smoke was quite heavy at the extremes, but went completely away when set back down to a normal range.
Anyway, just thought I'd mention it in case you still have some smoke when you're done with the heads. Can't hurt to fiddle a few more minutes with tuning after all.
Might even run better on the trail if you change a couple of settings here and there.
No matter what, have fun out on the trails!
mr incredible
rotate it through the firing order as you torque them down. i have used the rope trick .. it works good. get a 1/2 inch rope, made of some good jute. then roll as much of it into the cylinder as you can , then roll the engine up onto the rope. dont force any thing , just good and snug . then pop off the valve spring keepers and the springs.. and change out the seals.
Pa PITT
Stephenville TEXAS
I can't believe I've never hear that old trick with the rope . .
... Just get yourself a Bumper sticker and put it on your back window.
............... QUITYOURBELLYACHING !!......................
...& BE Glad PaPitt's DIESEL AIN'T in FRONT OF YOU!!!
.... I'm wanting a Bumper Sticker for my Bronco...
What do you like least about me.
MY NOISE!
MY SMELL! R
MY SMOKE!!
.. I'd do the stem seals I'd use some Pioneer Valve Stem Bonnet seals & I too would put at least one Qt of that Lucus oil stabilizer in it.
.... Back when I had my parts house I never thought the additives were the problem but most of the times when motor got down on their last leg people just quit changing the oil. They just kept adding oil to the old dirty oil inside.
.. But when you rebuild it you can vat it and replace everything and it's new again.
