This collar and turn signal switch mount replaces your stock gearshift collar and turn signal switch mount. If your column is an automatic you need both the turn signal switch mount and the smooth shift collar (2 or 3) $30. Your automatic turn signal switch mount does not have the mounting holes for the collar nor any room to drill them. I have turn signal switch mounts for both emergency flasher switch on the column (3) $30 and for the early ones that either don't have an emergency flasher switch or the switch is on the dash (2) $30. If you have a manual shift column now you can reuse your switch mount and save on shipping and the cost of the smooth collar (1) $25. Maximum shipping for all 50 states is $10.35 for both the collar and the switch mount. If you need only the smooth collar and mounting screws shipping is $4.95 for all 50 states.
