Quick question on your heim steer, it looks like the toe is set by using the double adjuster with right and left hand threads on the drivers side, do I have that right? Looks like a female heim on the drivers knuckle, going to a double adjuster with male threads on both sides, and then into a female tube end welded into the drivers side of the tie rod end?
If I have that right, do you mind sharing the vendor you bought the setup or parts from? Reason I ask is I have a similar setup that needs to maintain the clocking of the tie rod (in my case for my welded on ram assist attachment) versus your welded on drag link attachment.
Here's a pic of what I'm working with in case folks are interested. Given the current setup, I'm limited to half or full turns of heims to maintain proper ram assist alignment, which limits me to discrete toe settings - versus being able to set toe across a range. (step one is to get the ram assist more parallel to tie rod)
